![]() | Home > Technical (L322) > Sun roof adjustment |
marques.a Member Since: 17 May 2021 Location: Belo Horizonte Posts: 6 ![]() ![]() |
Axle, you are amazing, was about to take my entire sunroof apart |
Blencoe Member Since: 13 Apr 2018 Location: Gloucestershire Posts: 16 ![]() ![]() ![]() |
Hi folks, noticed the rear of my sunroof was down 4-5 mm from the roofline, I performed the “reset” as per this thread, placing the roof in the tilt position and then continue to hold the button until the clicks are heard, worked a treat. Thank you to all the guru’s on here who have helped me correct all the minor issues I’ve ever had with this great car. Thank you 👍 |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Hi, Guy`s
Ron Greevar Member Since: 03 Dec 2019 Location: Northants Posts: 63 ![]() ![]() ![]() |
Thank you FFRR forum.
Mark T Boldry Member Since: 08 Feb 2019 Location: York Posts: 29 ![]() ![]() |
This has annoyed me no end... Time is not my friend, but today I have some spare, so a few little jobs sorted including getting the sunroof FLUSH with the roof line.... Many thanks guys..! |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
It's a very simple but very satisfying fix, isn't it?
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
I’ve joined the many on here who have derived great satisfaction from doing this reset and having a nice flush sunroof. Thanks again for the forum knowledge. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1268 ![]() ![]() ![]() |
Since disconnecting my battery my sunroof won't go to the tilt position to do this procedure.
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
Just bringing this to the top of the pile. Have a look at your sunroof and if it sits a bit low at the back just use this simple reset procedure.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Just randomly glanced at the car whilst I was putting stuff in the outside bin… sunroof looked a bit low at the rear. Had a bit of wind noise on motorway trips recently that wasn’t there before, did the reset and it’s all back flush again. I remembered there was a procedure but couldn’t remember if it was hold up or forward. The up to the tilt position and hold did the trick. Then just fully open then close the roof.
Had this when I first got the car 20months ago and it was an easy fix. Never operated the sunroof since for fear of it not closing again……. 2012 TDV8 Vogue (L322) |
Daz90 Member Since: 12 Nov 2023 Location: Bristol Posts: 40 ![]() ![]() |
Amazing!
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
Another big thank you for this, I was getting a crazy amount of wind noise and thinking my last one was much quieter, have had a look at something else on the roof, I noticed the sun roof was sitting 5mm lower than the roof line- that’ll be the reason for the wind noise then!!!
GregPrice80 Member Since: 25 Jan 2024 Location: Exmouth Posts: 41 ![]() ![]() ![]() |
Another successful adjustment this morning. This is like a chiropractor for FFRRs |
