Home > Technical (L322) > Sun roof adjustment
Page 3 of 4 <1234>
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
All you should need to do is fully tilt the sunroof and keep your finger on the button for about 30 seconds or until you hear a clunk.
Close the sunroof. Slide the sunroof fully open then close t. Job done.
If yours doesn't sit flush at that point then you'll need to reposition the brackets.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #564321 12th Aug 2020 1:48pm
marques.a
Brazil
Axle, you are amazing, was about to take my entire sunroof apart Shocked
You saved many hours of work and sweat! Bow down
thank you very much friend
Post #598669 25th Jun 2021 4:34am
Blencoe
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Hi folks, noticed the rear of my sunroof was down 4-5 mm from the roofline, I performed the “reset” as per this thread, placing the roof in the tilt position and then continue to hold the button until the clicks are heard, worked a treat. Thank you to all the guru’s on here who have helped me correct all the minor issues I’ve ever had with this great car. Thank you 👍
Post #598862 26th Jun 2021 2:32pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Guy`s
Did what it said on the box and works for me? thanks, FFRR forum Thumbs Up
Post #598878 26th Jun 2021 6:31pm
Ron Greevar
United Kingdom 2011 Range Rover Vogue 4.4 V8 Galway Green
Thank you FFRR forum.
It really bugged me that my sunroof didn't fully close, but just spent a happy minute following the above tutorial and - it now sits flush with the roofline!
Anyone know if the same can be done with a 2007 Freelander 2 whose sunroof currently will not work 'one touch' making getting the roof to close at the right point a right pain?
Ron Thumbs Up
Post #600513 13th Jul 2021 2:37pm
Mark T Boldry
This has annoyed me no end... Time is not my friend, but today I have some spare, so a few little jobs sorted including getting the sunroof FLUSH with the roof line.... Many thanks guys..! Smile
Post #606012 9th Sep 2021 9:28am
RRDunc
It's a very simple but very satisfying fix, isn't it?
Post #606146 10th Sep 2021 10:24pm
Davidmudley
I’ve joined the many on here who have derived great satisfaction from doing this reset and having a nice flush sunroof. Thanks again for the forum knowledge. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #621087 23rd Jan 2022 1:09pm
kevinp
Since disconnecting my battery my sunroof won't go to the tilt position to do this procedure.
Anybody shed any light please?
Thanks Kev.
Post #629249 20th Apr 2022 6:54pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Just bringing this to the top of the pile. Have a look at your sunroof and if it sits a bit low at the back just use this simple reset procedure.
Tilt roof up and hold button until you hear a clunk (about 30 secs) RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #643193 17th Sep 2022 11:20am
mjdronfield
Just randomly glanced at the car whilst I was putting stuff in the outside bin… sunroof looked a bit low at the rear. Had a bit of wind noise on motorway trips recently that wasn’t there before, did the reset and it’s all back flush again. I remembered there was a procedure but couldn’t remember if it was hold up or forward. The up to the tilt position and hold did the trick. Then just fully open then close the roof.
I tried it initially stood on the side steps with the door open… ignition on, and I didn’t get the clunk, so maybe door need to be shut. Hopefully wind noise is gone now.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #665194 27th May 2023 10:05am
JayGee
Had this when I first got the car 20months ago and it was an easy fix. Never operated the sunroof since for fear of it not closing again……. 2012 TDV8 Vogue (L322)
Post #665235 27th May 2023 5:45pm
Daz90
Amazing!
Picked my l322 up a few weeks ago and was wondering why it sounded like it was blowing a gale through the sunroof! Could only stop it by closing the blind.
Saw this thread and went out this morning and saw that my sunroof too had dropped slightly at the back. Tried this fix, went on the motorway and hey presto! Problem solved!!
Thank you all
Amazing 🤩
Post #684716 4th Feb 2024 12:34pm
TDV8 Paul
Another big thank you for this, I was getting a crazy amount of wind noise and thinking my last one was much quieter, have had a look at something else on the roof, I noticed the sun roof was sitting 5mm lower than the roof line- that’ll be the reason for the wind noise then!!!
Carried out the reset and hey presto, sunroof sitting flush and noticeably quiet especially at motorway speed!!!
Thank you very much 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #693118 22nd May 2024 11:39am
GregPrice80
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Another successful adjustment this morning. This is like a chiropractor for FFRRs Laughing
Thanks for the advice 👍🏻 2010 Range Rover 4.4TDV8 Autobiography Black Edition
Gone -
2005 Discovery 3 2.7 TDV6 S
2002 Range Rover 3.0 TD6 HSE
Post #693232 24th May 2024 7:56am
Page 3 of 4 <1234>
