![]() | Home > Maintenance & Mods (L322) > C1 or C3 Oil on a L322 2011 TDV8? |
The engine will be fine with C3. The DPF’s life will be shortened by how much I’m not sure. Why use C3 at all when C1 is available? 2012 TDV8 Vogue (L322) |
Fiorano575 Member Since: 28 Nov 2023 Location: High Wycombe Posts: 16 ![]() ![]() ![]() |
Thanks for that info.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 116 ![]() ![]() ![]() |
Thing is: Landrover doesn't specify ACEA C1 oil, or C2 or C3 for that matter.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
Is Syntium 5000 not the right oil (one of many, I use Smith and Allan), the C1 spec is still the C1 spec even though ACEA don't list C1 anymore the spec didn't change. Geoff |
Irrespective of the dropping of the C1 label the standard for the SAPS content still stands as the reason to choose low not mid SAPS oil for the DPF equipped 4.4. 2012 TDV8 Vogue (L322) |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1407 ![]() ![]() |
In the L405 thread, i think there was a semi-consensus that in the loss of C1, C4 would be the next closest suitable option as C2 and C3 were higher in contents that would potentially affect the DPF. ( by how much I dont know though ) V8 or else ... |
The only downside to C4 oils is they are / have to be thick to meet the 3,5 mPa.s HTHS.
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
Castrol is Land Rovers oil partner for fluids, for the 4.4tdv8 2010-2012 they recommend Ford WSS-M2C913 spec and the product for EU cars is Castrol MAGNATEC 5W-30 A5
Castrol recommend 'Edge' for the TD4.4 V8 with a DPF
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 72 ![]() ![]() ![]() |
I tried to follow the thread on the L405 forum on this topic and ended up hopelessly confused.
Smith & Allan, Opie Oils are a good place to start. Most places alow you to enter your reg or car model into the parts finders. It realy isn't that hard to find 5w 30 oil in C1 / low SAPS spec. 2012 TDV8 Vogue (L322) |
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 63 ![]() ![]() |
As listed by JayGee above, I’ve been using LiquiMoly 4500 in my 4.4 TDV8 for quite a while now and am very very happy with it. It’s practically the only option I can find readily that meets the C1 spec we need. I buy 20L canisters and change every 8,000km. No dpf problems (since I did the 3 O-Ring fix on the intake!). -------------------------
The only important specs for most people with a 4.4SD/TD V8 are the viscosity and the SAPS rating. If you are working the engine hard such as doing serious off roading, towing heavy trailers up hills or blasting down Autobahn's at >200kmh you may want to select a more expensive oil with higher quality base stock to deal with the extra heat and load but for everyone else the cheaper stuff is fine and change it at least 2x a year and at well under 1/2 the JLR recomended miles/Km's ( 5-7k miles seems to be the consensus) 2012 TDV8 Vogue (L322) |
Hey Jaydee
