![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 470 ![]() ![]() ![]() |
On my last trip to the UK. I monitored the values closely. I did manage to get 750km between Regens but part way into the holiday, I went for a motorway drive to get some passive Regens. It lowered the soot gram enough so that the active regen happened as expected. It is the lower-speed journeys that increase the soot lots.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 358 ![]() ![]() ![]() |
I would assume that rpm makes the difference. When I got the warning light (not red) I drove just a few miles (5-10) on the motorway in 6th gear at around 70mph.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1415 ![]() ![]() |
I think the regen process likes to engage fully on light over run, so if your cruising at speed and lighten the throttle, it’s an opportunity to shove more fuel down the pipe to get a burn.
Malbro Member Since: 22 Mar 2023 Location: Cumbria Posts: 17 ![]() ![]() ![]() |
So I decided to get the engine oil analysed on my 2016 sdv8 4.4 mostly to check the dilution %.Here are the results
GM260 Member Since: 17 Apr 2021 Location: London Posts: 3 ![]() ![]() ![]() |
And now in addition to all the monitoring, JLR is being taken to court in the UK and not just Australia over this issue:
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1260 ![]() ![]() |
Technically the DPF is not defective it works. So legally they need to be careful how they approach this.
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 166 ![]() ![]() ![]() |
I had the same problem with my 2015 TDV6 I've ended up using the Jaguar F Pace TDV6 profile. This gives me most but not all of the things that I need. |
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 22 ![]() ![]() |
Thanks for the information, I'll give it a try ![]() |
So, my regens have been triggered at 50% inferred or 20grams of soot for months now and distance between regens about 190miles. This week I did a 250 mile run and the % figure crept up to about 70 and soot at about 25g. No alarms and no regen. I stopped for a coffee and a de-stress and on starting off again it went straight into a regen. Great! and about 250 miles since last one. On the return journey, again no regen and soot at 80% and 30g ......no regen and 340 miles since last one. I thought retirement was all about relaxing and pruning roses..not megga stress situations. |
Since I had the DPF replaced under warranty and started using the kit to monitor regens, I have used Shell v-power diesel only.
![]() ![]() Must be a Gremlin or when you started in the morning you have a leaky hose? that can give you an amber and a straight red just after. I only go by the grams soot now, the % referred level is still a mystery to me and not very accurate. I usually get an auto regen around 20.7g and it switches off around the 5.5g mark. ![]() the only thing I can think that could prevent a regen starting is speed below 30mph -ish and maybe fuel tank level, some people have quoted 1/4 tank but I have seen regens happening just before the fuel light has happened so its anyones guess. I have seen it go above 21/22 but I often then bring in the 2nd turbo which usually kicks it off. I guess it could also be a loose wire on a sensor? I would love to know what the inputs are for the logic flow diagram etc 2018 SE SDV8 4.4 Byron Blue |
I'm thinking that I might drive it too carefully and it needs a bit of a blast ,maybe in sport mode to get it going. The profile that I'm using is for the Jaguar F Pace. It's the only one I can get to give me exhaust temps.
You have a DTC code reader, it will tell you if you have sensor issues just scan and clear faults. Start car then stop, and do another scan, see if same faults appear. No faults then monitor. Does the basic Range rover profile not work for you regarding exhaust temps?
Oh Well. Ignorance is bliss... or was bliss. Did some checking with the icarsoft today and I have no readings from 2 of the exhaust temperature sensors. Bank 1 sensor 2 and Bank 2 sensor 1. Also one of the EGR valves seems to be stuck closed. I don't suppose any of the above will help my regen situation.
