Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 469 |
On my last trip to the UK. I monitored the values closely. I did manage to get 750km between Regens but part way into the holiday, I went for a motorway drive to get some passive Regens. It lowered the soot gram enough so that the active regen happened as expected. It is the lower-speed journeys that increase the soot lots.
17th Apr 2024 5:55am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 344 |
I would assume that rpm makes the difference. When I got the warning light (not red) I drove just a few miles (5-10) on the motorway in 6th gear at around 70mph.
17th Apr 2024 6:20am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1393 |
I think the regen process likes to engage fully on light over run, so if your cruising at speed and lighten the throttle, it’s an opportunity to shove more fuel down the pipe to get a burn.
17th Apr 2024 7:22pm |
Malbro Member Since: 22 Mar 2023 Location: Cumbria Posts: 17 |
So I decided to get the engine oil analysed on my 2016 sdv8 4.4 mostly to check the dilution %.Here are the results
10th May 2024 11:23am |
GM260 Member Since: 17 Apr 2021 Location: London Posts: 3 |
And now in addition to all the monitoring, JLR is being taken to court in the UK and not just Australia over this issue:
17th May 2024 9:57am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1248 |
Technically the DPF is not defective it works. So legally they need to be careful how they approach this.
17th May 2024 10:33am |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 162 |
I had the same problem with my 2015 TDV6 I've ended up using the Jaguar F Pace TDV6 profile. This gives me most but not all of the things that I need. |
17th May 2024 6:28pm |
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 22 |
Thanks for the information, I'll give it a try |
22nd May 2024 1:11pm |
So, my regens have been triggered at 50% inferred or 20grams of soot for months now and distance between regens about 190miles. This week I did a 250 mile run and the % figure crept up to about 70 and soot at about 25g. No alarms and no regen. I stopped for a coffee and a de-stress and on starting off again it went straight into a regen. Great! and about 250 miles since last one. On the return journey, again no regen and soot at 80% and 30g ......no regen and 340 miles since last one. I thought retirement was all about relaxing and pruning roses..not megga stress situations. Anyway, today I started the car and the amber light came on, followed pretty quickly by the red one. Called the AA and they did a forced regen but curiously the soot was down to 6g when it started so the AA man thought it had done a regen but tripped the alarm in before it finished, the engine was stone cold. All back to normal now but I just wonder what it was all about. I'll be watching it like a hawk the next time it comes around but just wondering if anyone has any idea what would stop a regen from happening? My Icarsoft and the AA man's kit didn't show any faults.
22nd May 2024 3:53pm |
Since I had the DPF replaced under warranty and started using the kit to monitor regens, I have used Shell v-power diesel only.
22nd May 2024 5:03pm |
This did make me laugh But seriously check you have the correct profile just in case the soot calculation is different across each profile. See this chart, at 28.5g the Regen process is inhibited and the amber should be on at 24.5g red is on at 31.5g yet you state you were at 30g when you got home? with no lights!`If thats the case, Amber should have been on. Must be a Gremlin or when you started in the morning you have a leaky hose? that can give you an amber and a straight red just after. I only go by the grams soot now, the % referred level is still a mystery to me and not very accurate. I usually get an auto regen around 20.7g and it switches off around the 5.5g mark. the only thing I can think that could prevent a regen starting is speed below 30mph -ish and maybe fuel tank level, some people have quoted 1/4 tank but I have seen regens happening just before the fuel light has happened so its anyones guess. I have seen it go above 21/22 but I often then bring in the 2nd turbo which usually kicks it off. I guess it could also be a loose wire on a sensor? I would love to know what the inputs are for the logic flow diagram etc 2018 SE SDV8 4.4 Byron Blue |
22nd May 2024 8:02pm |
I'm thinking that I might drive it too carefully and it needs a bit of a blast ,maybe in sport mode to get it going. The profile that I'm using is for the Jaguar F Pace. It's the only one I can get to give me exhaust temps.
23rd May 2024 7:23am |
You have a DTC code reader, it will tell you if you have sensor issues just scan and clear faults. Start car then stop, and do another scan, see if same faults appear. No faults then monitor. Does the basic Range rover profile not work for you regarding exhaust temps?
23rd May 2024 9:16am |
Oh Well. Ignorance is bliss... or was bliss. Did some checking with the icarsoft today and I have no readings from 2 of the exhaust temperature sensors. Bank 1 sensor 2 and Bank 2 sensor 1. Also one of the EGR valves seems to be stuck closed. I don't suppose any of the above will help my regen situation.
24th May 2024 1:39pm |
