Home > General > What Did You Do In Your Full Fat Today
Page 371 of 382 <123 ... 370371372 ... 380381382>
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Last couple of days, got the sill covers off to check for corrosion - surprisingly none found Shocked but to be on the safe side coated all the surfaces to give extra protection before putting the covers back on.
Then got the wheels off and arches and underside cleaned down and some light surface rust treated with Hydrade 80 before then giving the whole underside (and myself Rolling Eyes ) a liberal coating of Lanoguard.
Post #691844 3rd May 2024 6:54pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Nitromors'd any exposed rust and Wayoyled the underbody, tailgate etc., now I have the big pamps, (sills and arches I did a while back), checked all round for leaks, stinks when hot now as I managed to get it all over the exhaust as well but that'll burn off in time.
Fitted the large bottle jack in the wheel well, threw away the standard widow maker scissor jack. Removed the rear window glass edge trim as was warped and looked terrible, just as good without it.
Greased all the door hinges as some were groaning a bit. Also cleaned the engine bay, I'll try to keep it this way.
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #691961 5th May 2024 2:00pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
New Rear Shocks
Changed the rear shocks yesterday and have an appointment with the RR-Indie for timingchain replacement.
After five years of carefree ownership of my fattie, the last six months have been rather expensive; mechatronic replacement 3500.00 (which would not have been necessary, this mechanic only got away without a trial because I had no proof) Censored new transfer box 1700.00 as consequential damage from the incompetent ZF-Indies, now another 5000.00 for the timing chain. Big Cry
At least I can now make my future trips to Andalusia without any worries. Thumbs Up
Post #692258 9th May 2024 2:08pm
AlexTVR
Thanks to this forum found the manual release for the lower tailgate after it wouldn’t open. Cleanup of the latches on the expanding todo list Smile 2010 Supercharged
Post #692269 9th May 2024 8:06pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Started the oil cooler exchange on my new to me 2011 4.4
Massive thanks again to all those who add priceless info on here Bow down Bow down Bow down Bow down 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE
Post #692276 9th May 2024 10:07pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Tackled the 'Sticky Buttons' on the air suspension controls. I had tried a few different remedies without success but after watching a YouTube video I tried Isobutyl Alcohol and it worked a treat. A bit fiddly but well worth the effort.
Post #692285 10th May 2024 8:32am
Weegie
Went to the garden centre where MOH spent money. Smile John
GAP iiD BT-Sold
Post #692306 10th May 2024 2:32pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Enjoyed the sunshine and used the time to give a full spring valet inside and out and then spent 20 minutes sitting on my wall, sipping a cold one and thinking how lucky I am to be able to own, maintain and drive such a magnificent beast! Thumbs Up Thud _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #692308 10th May 2024 3:02pm
landy95
Over the last 3 days NS Front Air spring replaced.
NS & OF rear brake pipes replaced in full with cupro nickel, both rear flexis replaced and system bled. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned 1991 Range Rover Vogue 3.9 V8.
Post #692566 13th May 2024 10:13pm
AlexTVR
Had a new windscreen fitted, didn’t notice until they’d left that they had forgotten to fit a moulding back in at the top of the screen Sad 2010 Supercharged
Post #692633 14th May 2024 5:09pm
StuManchu
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
On a tour in mine at the minute, trying out the set up, seeing what works and what doesn't, currently residing on the Isle of Arran...
Post #692815 16th May 2024 9:31pm
AndyRoo
MOT passed today, no advisories - result Thumbs Up Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #692854 17th May 2024 2:20pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Today I am tackling changing the oil on the auto box. I bought 20L of Transguard 8 from Smith & Allan. My plan is to just do an oil change today and then drive it for a month and drop the oil again and also change the sump/filter. That way I think I should have a good flush and replace most of the fluid.
The fluid that came out was looking fairly black so obviously it was due a change. I am just about to hit 60k miles so I am in line with what ZF (but not LR) recommend.
Post #692896 18th May 2024 1:32pm
MC-RR
Monaco 2012 Range Rover HSE 4.4 V8 Ipanema Sand
Tackled a brake bleed on the beast today, all in all 2 hours and just under 2 litres.
Been a couple of years and fluid was looking rather cooked. Since we do a lot of mountain driving as well as driving quite fast on the Autostrade it was definitely due
Did feel a positive difference Very Happy
Thank you all for the helpful posts on FullFatt.com Smile Great inspiration
 RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Triumph TR6 1976 - Jeep CJ7 1976
Post #692922 18th May 2024 10:12pm
TomC-RRV8
Did a full machine 3 stage Polish on mine yesterday, transformed the paint finish now mirror finish all round very pleased!
. Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #692947 19th May 2024 10:25am
