Home > My Range Rover > 2012 Vogue TDV8 |
Hoylio Member Since: 30 Mar 2024 Location: North Wales Posts: 17 |
Superb colour combo! Nice find!
1st Apr 2024 4:09pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
All of that can be sorted. At least it’s honest. Most likely would have needed bodywork on the arches, even without farm use.
1st Apr 2024 4:29pm |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 168 |
Yes, it needs plenty of elbow grease but that's fine. After I am back from holiday next month I will post a wanted-parts list. |
1st Apr 2024 7:40pm |
I have ordered a new set of wheel nuts and thanks to this thread, https://www.fullfatrr.com/forum/topic61127...t=heating, £25-worth of top quality Chinese changeover valve. |
2nd Apr 2024 1:06pm |
Oh dear. An overheating warning but I caught it quickly. Fortunately the truck was only 15 minutes away so I'm back home waiting for it to cool. It does not crank though but it was OK when it loaded onto the truck.
6th Apr 2024 7:34pm |
I disconnected the battery for an hour and it started. There was a low coolant warning so more investigation required. I topped up with the orange coolant, hopefully that is correct as Halfords website said so but its in-store book said blue.
7th Apr 2024 2:32pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 334 |
Similar to the noise mine makes when cold. And it uses a small amount of coolant, maybe a litre every 500 miles. Perhaps it’s the water pump? |
7th Apr 2024 2:59pm |
Yes, certainly possible. I think I'll replace the 'stat anyway but I will inspect the system. I need to order the fan coupling spanner thingy. |
7th Apr 2024 4:09pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3179 |
slow coolant leak could be EGR Cooler. |
8th Apr 2024 7:14am |
A mixed bag today. The easiest job was replacing the locking wheel nuts and throwing them in the bin.
13th Apr 2024 7:01pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 126 |
Assuming the L322 uses the same 'quick fit' coolant hose couplings as the L405, then they are all prone to weeping! I've changed numerous hoses on mine. The o-ring goes flat, then the coupling leaks slightly. I've still got one leaking somewhere!
14th Apr 2024 6:12am |
My new hose clamp pliers arrived. The top two hoses were a doddle but I cannot release the lower hoses as the clamps are 90° turned away and thus there is no room. If the fuse box wasn't there it would be a lot simpler.
18th Apr 2024 6:28pm |
Intake hoses: There is some misting present so some new hoses required later.
18th Apr 2024 6:53pm |
Some more slow progress and profanity but I have the most difficult hose on the valve.
26th Apr 2024 1:43pm |
