Home > Technical (L322) > I’m in trouble here
Page 2 of 3 <123>
Adhesive ? .
Post #689845 3rd Apr 2024 7:53pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Looking at my photo, does anyone know if the broken connector pipe is the one that joins the filler neck, or is it the one that connects to the metal fuel pipes that go to the engine?
I have a looked at the information kindly put up by Weejock and Richie N but am not sure where the pipe goes to, or which pipe to buy?
This is very difficult to establish on the car without removing a lot of parts.
Joe90 I am not sure that any adhesive would be a permanent fix even if I could do it with glue due to diesel contamination.
Many Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689926 4th Apr 2024 6:20pm
It looks to me like you have to remove the tank to gain access to those pipes, that means exhaust system removal and rear propshaft, then drop the tank, it's a huge job for a beginner and there are lots of other bits that will break easily...
Sorry to say it but if I were you I'd get it taken to a garage and chalk it up to experience....
Good luck
Oh and if your not careful the large rubber gasket on the tank fitting will partially fall off as you screw the big ring on, it then pulls up one side more than the other and gives the symptoms you have, a leak and a spinning tank attachment, this can damage the rings and the tank and unless replaced will nearly always leak... Pete
Post #689931 4th Apr 2024 7:22pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Perhaps this guy can help or identify the pipe for you…
https://www.ebay.co.uk/itm/266340728575?mk...media=COPY
Post #689938 4th Apr 2024 7:50pm
Richie N
I also echo Haylands thoughts and it is most definitely going to require the tank to be dropped.
Post #689940 4th Apr 2024 8:00pm
Buellie
Wished I had left the faulty fuel gauge now Big Cry
I really don't know where to go with it now. I'm in Essex, I assume it would need to be a Range Rover specialist garage any recommendations please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689943 4th Apr 2024 8:23pm
Richie N
Fuel pipe repair kit ? Looks like the plastic connector.
https://www.johncraddockltd.co.uk/range-ro...and-clips/
I believe the pipe is the fuel feed pipe not the return. As per this thread:
https://www.rangerovers.net/threads/2008-l...ge.292138/
Post #689944 4th Apr 2024 8:31pm
Good find, that may work... Thumbs Up
You still need to get the unit out the tank and reseat it and the gasket correctly if it's not too badly damaged... Pete
Post #689945 4th Apr 2024 8:50pm
Buellie
Thanks Ritchie
I think it is the fuel pressure pipe too, looking at the thread you pointed out.
I suspect the way forward is to try and repair the pipe with a new connector. I assume the link is for the Norma repair kit. I am wondering if I could cut the pipe and repair it with a new connector. The cost to drop the tank, etc would probably be into thousands and I really cant do that right now, also I don't know anybody that I could trust to do it as it my first Range Rover that I've only had a few weeks.
My thinking is try and repair the pipe, cure any leak around the pump with some type of mastic as it was not major and I don't think that I can remove the cap without damage, not ideal I know. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689946 4th Apr 2024 8:59pm
Richie N
Yes, I agree, I would look at a repair first. I would contact the company and confirm that the connector will fit. And go from there.
Is there no way to reattach the cap properly?
Post #689949 4th Apr 2024 9:27pm
Buellie
The ring is very tight and I cannot now remove it because the whole cap moves with it.
I will sort the pipe first (hopefully) and worry about that afterwards
Thanks for your help Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689953 4th Apr 2024 9:50pm
Richie N
Just take your time Wink
Good luck and keep us posted. Thumbs Up
Post #689977 5th Apr 2024 9:13am
Buellie
I have managed to source a couple of connectors.
The plan is to remove to old connector from the pipe.
Rather than cut the pipe to remove the wire ld one, is it possible to remove the old connector with some heat from a hairdryer or are they hammered in too hard?
I think I’m only getting one go at this so don’t want to mess things up Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690060 6th Apr 2024 9:27am
Buellie
After a breather and some thinking the answer to my predicament was straightforward.
I could not source the exact connector to match the original anywhere, however I managed to find this on Amazon £7.49
The male connector is very similar and the same diameter. I also bought some 7 and 8 mm rubber petrol pipe.
I asked on here what the fuel pressure is and found it to be 0.5 bar, around 7psi from the pump in the tank, It then runs to a secondary pump which increases it to 5.5 bar. So it is under very little pressure.
The connecters that I bought required a small modification in removing the secondary larger ring in the picture with some side cutters and a file.
The broken connector had around half an inch (old school) intact. So I managed to connect the rubber fuel pipe onto the broken connector and the other end to the new male connector, securing with small jubilee clips. The rubber pipe is around 1.5 inches long and 7mm internal diameter.
Anyway we are up and running again all good, and just wanted to document this repair in case anyone else is as stupid as me and breaks a connector.
Post #690434 11th Apr 2024 6:51pm
Richie N
Good man 👍 where there’s a will …….
Post #690442 11th Apr 2024 10:46pm
Page 2 of 3 <123>
