![]() | Home > Technical (L322) > I’m in trouble here |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Adhesive ? .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8558 ![]() ![]() ![]() |
It looks to me like you have to remove the tank to gain access to those pipes, that means exhaust system removal and rear propshaft, then drop the tank, it's a huge job for a beginner and there are lots of other bits that will break easily...
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
Perhaps this guy can help or identify the pipe for you…
I also echo Haylands thoughts and it is most definitely going to require the tank to be dropped. |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 153 ![]() ![]() ![]() |
Wished I had left the faulty fuel gauge now |
Fuel pipe repair kit ? Looks like the plastic connector.
Good find, that may work... |
Thanks Ritchie
Yes, I agree, I would look at a repair first. I would contact the company and confirm that the connector will fit. And go from there.
The ring is very tight and I cannot now remove it because the whole cap moves with it.
Just take your time |
I have managed to source a couple of connectors.
After a breather and some thinking the answer to my predicament was straightforward.
Good man 👍 where there’s a will ……. |
