Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
hmm lower control arm came off okay, the upper though turns out you need to drop the subframe, balls should have just done it yayday.
31st Mar 2024 2:06pm |
right all done, once i dropped the subframe it was actually all rather easy.
31st Mar 2024 4:25pm |
So LR have said the rear disc dust shields are on back order and no stock anywhere...fml Its actually a sport
3rd Apr 2024 12:39pm |
managed to get off the other knuckle/hub out other day.
7th Apr 2024 4:36pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 111 |
If you have removed the Caliper from the car fit a suitable grease nipple to an open port and pump grease in, not failed yet for me. Kevin
7th Apr 2024 9:12pm |
everything is off the car now
Ill need to check mine but is it because it assumes the cables are more or less impossible to remove? Mine is working completely fine. Its actually a sport Not anymore, 4.4 TDV8 now |
8th Apr 2024 8:00am |
this so much. i spent an hour with an air compressor at about 100psi with nothing and managed to actually get a seal. i order and hook up a grease gun and boom, straight out, no dramas. also debushed one of the upper control arms. it was a bit of a nightmare, bent my rod, but then a quick blast with some heat and away we go Its actually a sport Not anymore, 4.4 TDV8 now |
12th Apr 2024 8:38am |
i noticed when reinstalling the bushes for an upper control arm that the holes in them can take an M16 which stock could only take M14. Its actually a sport
12th Apr 2024 8:19pm |
got the other side all stripped down as well.
13th Apr 2024 5:06pm |
well went away drinking and eating in naples so havent had a chance to work on this.
29th Apr 2024 12:43pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Just catching up on this now, it’ll be well worth it when you’ve finished. The 2007 car I did this to felt like a new car after I’d finished it. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
29th Apr 2024 2:03pm |
I was mostly inspired by your subframe drop.
29th Apr 2024 2:11pm |
edit: i accidently deleted my original post, id written something that more or less went like
30th Apr 2024 3:23pm |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 52 |
mgrover,
1st May 2024 2:09pm |
