![]() | Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
hmm lower control arm came off okay, the upper though turns out you need to drop the subframe, balls should have just done it yayday.
right all done, once i dropped the subframe it was actually all rather easy.
So LR have said the rear disc dust shields are on back order and no stock anywhere...fml Its actually a sport |
managed to get off the other knuckle/hub out other day.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
If you have removed the Caliper from the car fit a suitable grease nipple to an open port and pump grease in, not failed yet for me. Kevin
everything is off the car now
Ill need to check mine but is it because it assumes the cables are more or less impossible to remove? Mine is working completely fine. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
this so much. i spent an hour with an air compressor at about 100psi with nothing and managed to actually get a seal. i order and hook up a grease gun and boom, straight out, no dramas. also debushed one of the upper control arms. it was a bit of a nightmare, bent my rod, but then a quick blast with some heat and away we go Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
i noticed when reinstalling the bushes for an upper control arm that the holes in them can take an M16 which stock could only take M14. Its actually a sport |
got the other side all stripped down as well.
well went away drinking and eating in naples so havent had a chance to work on this.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3209 ![]() ![]() ![]() |
Just catching up on this now, it’ll be well worth it when you’ve finished. The 2007 car I did this to felt like a new car after I’d finished it. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
I was mostly inspired by your subframe drop.
edit: i accidently deleted my original post, id written something that more or less went like
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 60 ![]() ![]() ![]() |
mgrover,
