Home > Technical (L322) > lost communication with abs module won't start |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2556 |
Has it been through deep water recently? The transfer case control module, which is mounted in front of the brake m/c, is open at the bottom as are its connectors. If water gets in and corrosion sets in on the connector contacts or on the pcb itself then it can cause HS canbus faults. The TCCM could be unplugged to see if the other faults can be cleared. |
31st Mar 2024 11:28pm |
Nic_101 Member Since: 31 Mar 2024 Location: England Posts: 11 |
no deep water, I checked the connectors which seemed fine but on other posts it seems you need to open it up to find moisture damage on the pub is that right?
1st Apr 2024 7:55am |
They TCCU is easy to open to check. IIRC one from another similar vehicle (MY10-12 L322 for you) will work as is.
1st Apr 2024 10:11am |
is the TCCU the transfer module? sorry for my lack of knowledge with the specific names, if so ive opened that one up its completely clean looks like brand new and so do the connectors ive wiggled and reseated a few connectors all of which havnt changed the codes yet,
1st Apr 2024 10:47am |
Yes, TCCU is transfer case control unit.
1st Apr 2024 11:07am |
thanks ive checked under the rear seat the cables kind of run down the inside of the wheel arch if that makes sense my interior is ivory so I removed the ivory trim cover once the back seat was folded forward and then there the bundle of wires are there however they all seem untouched and in good shape, ill disconnect the PCM now and see what happens thanks again |
1st Apr 2024 11:26am |
is the BCM on the back of the fusebox in the glove box? can this be removed to check if codes reset?
1st Apr 2024 2:52pm |
I wouldn't disconnect the BCU as it is part of the fuse panel.
1st Apr 2024 7:54pm |
Hi,
1st Apr 2024 11:38pm |
Workshop manual. IIRC there's a link in the Wiki to a site from which it can be downloaded. |
2nd Apr 2024 2:25am |
https://www.fullfatrr.com/gallery/albums/u...peed~0.pdf
2nd Apr 2024 3:43am |
ive had battery disconnected for longer than 30 seconds and reconnected but still same, but I never touched the connectors which many have suggested in other threads is that worth a try do you think? thanks |
2nd Apr 2024 5:31am |
I don't know what connectors are being suggested in another thread but give them a try. |
2nd Apr 2024 5:42am |
disconnecting the battery connectors and shorting touching them together before reconnecting I meant sorry |
2nd Apr 2024 6:49am |
