Home > Technical (L322) > lost communication with abs module won't start
Bricey21
United Kingdom 2011 Range Rover Vogue SE TDV8 Barolo Black
Did you get this resolved? I have a very similar issue with my 4.4 tdv8 and have tried everything on this post
Post #693564 29th May 2024 2:35pm
Nic_101
United Kingdom 2011 Range Rover SE TDV8 Java Black
hi,
it turned out to be the abs fuse within the fusebox behind the glovebox, it is easy to put it back in the wrong place too, the fuse diagram has to be turned clockwise 90 degrees before reading it I think.
there are fuses behind the battery which corrode too worth checking those
Post #693592 29th May 2024 9:34pm
