![]() | Home > Maintenance & Mods (L405) > Unusual Lower Tailgate problem |
WeeJ Member Since: 12 Aug 2012 Location: Aberdeen Posts: 29 ![]() ![]() |
I have a slightly different lower tailgate problem.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
The rubber either side of the lower tailgate controls the opening /closing check if its intact. 2017 SDV8 4.4 silicon silver AB
I wasn’t aware of the gesture part. thanks. 1998 Freelander XEdi
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1669 ![]() ![]() ![]() |
Hi WeeJ,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
I too would recommend deactivating the keyless function... |
Deactivated.
You are right, -if they were activated by closure, it would be the same as an obstruction, and open the gate. Not the desired result! |
Have you checked your battery SOH?
SOLVED
