Home > Maintenance & Mods (L405) > Unusual Lower Tailgate problem
WeeJ
I have a slightly different lower tailgate problem.
When I open the rear tailgate using the kick gesture, both halves open. When I press the close button on the lower tailgate it closes but it won’t open again nor open using this switch in any other mode.
When I open the upper tailgate using button or driver’s internal button only the top opens, the lower remains closed and the switch on the lower tailgate does nothing.
The fact it closes when I use gesture, suggests the switch works.
I’ve tried the logic reset with tailgate fully open and pressing the upper switch for 10 seconds.
Any ideas?
Everything moves smoothly, suggesting no friction, lube or alignment issue. I’m think switch dodgy but as it works with gesture I’m not so sure. 1998 Freelander XEdi
2003 Freelander HSE
2006 Freelander V6
2006 Disco 3 TDV6
2012 Range Rover Vogue L322
2014 Range Rover Vogue 2014 L405
2017 Range Rover Vogue 2017 L405
2021 Mercedes GLE400d AMG Premium Line
2024 Range Rover Westminster 2021 L405
Post #688323 18th Mar 2024 10:20am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The rubber either side of the lower tailgate controls the opening /closing check if its intact. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #688325 18th Mar 2024 10:31am
Gremlin500
@WeeJ:
Sorry I can’t help with your tailgate issue, but you might want to disable your gesture tailgate anyway, which also means disabling keyless entry to help prevent “relay theft” at the same time? Were you aware of this?
I think the dash button only opens the upper liftgate in any case, not both, but the fob (or gesture) should open both. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #688328 18th Mar 2024 11:06am
WeeJ
I wasn’t aware of the gesture part. thanks. 1998 Freelander XEdi
2003 Freelander HSE
2006 Freelander V6
2006 Disco 3 TDV6
Post #688370 18th Mar 2024 10:08pm
Gremlin500
Hi WeeJ,
See: https://www.google.com/url?sa=t&rct=j&...i=89978449
Strongly recommended to do this immediately. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #688380 19th Mar 2024 12:15am
I too would recommend deactivating the keyless function... Thumbs Up
Post #688381 19th Mar 2024 12:55am
WeeJ
Deactivated.
Rubbers all okay, checked both sensors and they operate. They sense obstructions on closing and stop further movement. But when closed these sensors are not operated against the body of the car. Doesn’t look to be out of line so `i suspect they’re not meant to. anyone know if there’s do or they should? 1998 Freelander XEdi
2003 Freelander HSE
2006 Freelander V6
2006 Disco 3 TDV6
Post #688837 24th Mar 2024 1:09am
Gremlin500
You are right, -if they were activated by closure, it would be the same as an obstruction, and open the gate. Not the desired result! Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #688860 24th Mar 2024 12:40pm
Gremlin500
Have you checked your battery SOH?
Operating the tailgate uses a significant current, and can cause system voltage to drop and interfere with all sorts. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #688861 24th Mar 2024 12:42pm
WeeJ
SOLVED
Broken wire from lower tailgate switch 1998 Freelander XEdi
2003 Freelander HSE
2006 Freelander V6
2006 Disco 3 TDV6
Post #698558 21st Aug 2024 9:35pm
