Home > Technical (L405) > B1D55-Antenna 2 circuit |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
The DAB antenna is located in the rear spoiler. The connector may have become dislodged at some point. It's easy enough to remove the rear spoiler to take a look. Only a few bolts. Kev
10th Mar 2024 7:54pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 87 |
When you say rear spoiler - do you mean the one at the top of the rear tailgate, so it opens with the tailgate? Not the sharks fin?
10th Mar 2024 8:15pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1109 |
The DTC from WSM are below, maybe corrosion/water ingress etc?
10th Mar 2024 9:11pm |
Thanks! I see a little job coming up for a sunny day...
10th Mar 2024 9:25pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Hi ChrisJC,
11th Mar 2024 12:48am |
Tailgate has dropped - which does bug me! So thanks for the tip.
11th Mar 2024 7:41pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1260 |
Kot, regarding the above picture with antenna / amp locations, what year is that WSM manual for?
21st Mar 2024 12:49pm |
Some serious corrosion, glad you found the fault.
21st Mar 2024 2:18pm |
Yup - the second set of WSM pictures match what I have - so all good.
21st Mar 2024 2:30pm |
21st Mar 2024 2:36pm |
Not sure VIN will make much difference ...
21st Mar 2024 4:02pm |
Was going to put this in a different thread, but then thought keep it all together as its all relevant to the original post.
21st Mar 2024 4:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34956 |
clever ... - .- -.
21st Mar 2024 4:27pm |
( I'm just dumping info into here so it can be referred to if anyone needs it further down the line )
24th Mar 2024 5:24pm |
