Home > In Car Electronics (L322) > DAB no signal
Page 2 of 3 <123>
bastion
The Dab in my car has gone foggy to say the least, is the weather????
Post #667231 21st Jun 2023 2:19pm
Dgeczi
be interested to know a fix, My DAB not worked for probs 3 years just use the normal AM/FM but is very annoying
Done the rescan and messed with all the settings but nothing, same with the auto stop/start this again not worked for years
Post #670828 9th Aug 2023 1:07pm
Dazzab1972
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
I have the same problem, just stop working?
Have tried all the usual tips but still no signal.
is there a DAB module?
Post #671715 22nd Aug 2023 7:07am
mrtomyard
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
I replaced my DAB module today, DAB back working perfectly! I did have fault codes stored for no communication with DAB module so worth a plug in 2011 Vogue 4.4 TDV8
2009 D4 HSE
2003 Freelander
2001 D2 TD5
1963 Series 2a 109 Truck Cab
Post #686384 24th Feb 2024 8:56pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
DAB Module
Can you say where your DAB module was found and identify part number etc. please. I did look for stations during a search last year on my 2012 Westminster but found nothing. Had the car for 7 years but may have never worked although has the right selection buttons needed?
Big Cry
Post #686682 28th Feb 2024 2:40pm
mrtomyard
So part number is LR019261 and it’s located very low behind the left hand removable side panel in the boot, did the job with basic tools and a glass of wine on the go on the driveway, easy job! 2011 Vogue 4.4 TDV8
2009 D4 HSE
2003 Freelander
2001 D2 TD5
Post #688301 17th Mar 2024 7:34pm
Nylands
DAB module
Many thanks Mr Tom, I'll have a look there.
Post #688334 18th Mar 2024 11:06am
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I have this No DAB issue too, but also have a crackly phone signal and weak FM signal which gets worse when the heated rear window is on. Can anyone recommend a fix for this please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #688371 18th Mar 2024 9:10pm
Buellie
Replaced the DAB module in the boot, all good now 👍🏻 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690102 6th Apr 2024 4:25pm
Strawman
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
No DAB radio check this out from about 5:50 worked for me on my 2011 4.4 same problem worth checking as its cheap.
Post #692781 16th May 2024 12:57pm
JonnyCJ
United Kingdom 2004 Range Rover Vogue 4.4 V8 Epsom Green
You can upgrade the DAB to later model DAB+ using either of these
https://www.ebay.co.uk/itm/305726113556?_s...R_q227SZZQ
https://www.ebay.co.uk/itm/135528730041
Post #710907 3rd Feb 2025 10:12am
those bits do not include the required upgraded DAB+ module.... ... - .- -.
Post #710912 3rd Feb 2025 11:07am
JonnyCJ
Correct - however there is part number in one of the links for the DAB+ module and there’s plenty on eBay and at breakers.
Post #710913 3rd Feb 2025 11:10am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I have one from L494. Same part number listed.
But you have to turn radio off then press DAB to use it.
And the same when trying to come out of it.
It works but not ideal.
Post #711183 5th Feb 2025 11:06pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
would be interested if anyone has got the DAB+ upgrades to work, have seen a load of previous threads where one person said they had and then no one else has been able to replicate it.
has anyone actually managed to get this to work - would be nice to know before spending out on it Smile 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #711263 6th Feb 2025 7:50pm
Page 2 of 3 <123>
