Home > In Car Electronics (L322) > DAB no signal |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I assume you have tried an auto retune?
28th Dec 2020 7:24pm |
OO__OO Member Since: 15 May 2014 Location: Manchester Posts: 18 |
Yes, tried rescanning but no signal so will not receive anything. Austin Champ - First car I owned in 1967 ETE167F
28th Dec 2020 8:53pm |
basil Member Since: 09 Dec 2014 Location: UK Posts: 88 |
Have you installed a dash cam by any chance? |
28th Dec 2020 9:25pm |
Hmmm, yes I do. I had a problem with my 2002 Rangie with very poor VHF reception caused by a dashcam in the rear window.
28th Dec 2020 10:18pm |
There is a well known issue with cabling (esp Dashcam) following the same path as DAB cabling - it kills the signal. Only way to prove this is to remove the dashcam cable - Power off will still leave the ability fo the cable to coal up the nearby signal. |
28th Dec 2020 10:22pm |
I've disconnected the power to the dashcam at source, a USB power supply which I unplugged. It is just a 5v supply & runs up the drivers front pillar to top of the screen, not near the DAB aerial lead I don't think.
29th Dec 2020 5:59pm |
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 |
Did you get to the bottom of this? No DAB on mine either! |
13th Jan 2021 6:30pm |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 517 |
My dashcam wiring goes along the windscreen under the headlining, down the passenger a-pillar and into the fusebox behind the glovebox. The cable for the rear camera goes along the headlining and along the drivers side of the car and I have no issues with my DAB reception.
13th Jan 2021 7:13pm |
So to add a little intrigue, my battery was flat this morning. My fault as I’d left it unlocked for 4 days so it hasn’t shut down properly. Jump started it off the defender and DAB worked perfectly! However it then started to crackle out and now we’re back with no signal. So I’m wondering if it’s a voltage problem somewhere along the line |
21st Jan 2021 11:19am |
MuddyTDi Member Since: 13 Nov 2022 Location: Leeds Posts: 12 |
Any updates on this? I have the same issue on a 2011 TDV8 Vogue
7th Jan 2023 12:59pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
Watching with interest, as I'm sure the DAB in my 2011 5.0 S/C used to be 100% solid anywhere, and has become a bit patchy/selective in the last year or so, but I thought maybe it was just me! |
7th Jan 2023 11:00pm |
mrtomyard Member Since: 04 Apr 2022 Location: Lincolnshire Posts: 12 |
Anyone had any joy with this? DAB has packed up completely today… no reception, won’t auto tune and no idea where to start looking 2011 TDV8 2011 Vogue 4.4 TDV8
19th Feb 2023 8:34pm |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
Same for me, used to work perfectly and now have no signal |
31st Mar 2023 11:43am |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 |
I doubt that your battery problem comes from not locking yor car, I never lock my car in my garage, even when I am on vacation for 2 weeks and my battery has never been flat. Maybe this is related to the DAB problem? DAB sucks battery or weak battery no reception? |
31st Mar 2023 1:31pm |
