Home > In Car Electronics (L322) > DAB no signal
bastion
The Dab in my car has gone foggy to say the least, is the weather????
Post #667231 21st Jun 2023 2:19pm
Dgeczi
be interested to know a fix, My DAB not worked for probs 3 years just use the normal AM/FM but is very annoying
Done the rescan and messed with all the settings but nothing, same with the auto stop/start this again not worked for years
Post #670828 9th Aug 2023 1:07pm
Dazzab1972
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
I have the same problem, just stop working?
Have tried all the usual tips but still no signal.
is there a DAB module?
Post #671715 22nd Aug 2023 7:07am
mrtomyard
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
I replaced my DAB module today, DAB back working perfectly! I did have fault codes stored for no communication with DAB module so worth a plug in 2011 Vogue 4.4 TDV8
2009 D4 HSE
2003 Freelander
2001 D2 TD5
1963 Series 2a 109 Truck Cab
Post #686384 24th Feb 2024 8:56pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
DAB Module
Can you say where your DAB module was found and identify part number etc. please. I did look for stations during a search last year on my 2012 Westminster but found nothing. Had the car for 7 years but may have never worked although has the right selection buttons needed?
Big Cry
Post #686682 28th Feb 2024 2:40pm
mrtomyard
So part number is LR019261 and it’s located very low behind the left hand removable side panel in the boot, did the job with basic tools and a glass of wine on the go on the driveway, easy job! 2011 Vogue 4.4 TDV8
2009 D4 HSE
2003 Freelander
2001 D2 TD5
Post #688301 17th Mar 2024 7:34pm
Nylands
DAB module
Many thanks Mr Tom, I'll have a look there.
Post #688334 18th Mar 2024 11:06am
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I have this No DAB issue too, but also have a crackly phone signal and weak FM signal which gets worse when the heated rear window is on. Can anyone recommend a fix for this please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #688371 18th Mar 2024 9:10pm
Buellie
Replaced the DAB module in the boot, all good now πŸ‘πŸ» Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690102 6th Apr 2024 4:25pm
Strawman
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
No DAB radio check this out from about 5:50 worked for me on my 2011 4.4 same problem worth checking as its cheap.
Post #692781 16th May 2024 12:57pm
