Home > In Car Electronics (L322) > DAB no signal |
bastion Member Since: 17 Oct 2018 Location: uk Posts: 26 |
The Dab in my car has gone foggy to say the least, is the weather???? |
21st Jun 2023 2:19pm |
Dazzab1972 Member Since: 13 Dec 2018 Location: Orpington Posts: 9 |
I have the same problem, just stop working?
22nd Aug 2023 7:07am |
mrtomyard Member Since: 04 Apr 2022 Location: Lincolnshire Posts: 12 |
I replaced my DAB module today, DAB back working perfectly! I did have fault codes stored for no communication with DAB module so worth a plug in 2011 Vogue 4.4 TDV8
24th Feb 2024 8:56pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
Can you say where your DAB module was found and identify part number etc. please. I did look for stations during a search last year on my 2012 Westminster but found nothing. Had the car for 7 years but may have never worked although has the right selection buttons needed?
28th Feb 2024 2:40pm |
So part number is LR019261 and itβs located very low behind the left hand removable side panel in the boot, did the job with basic tools and a glass of wine on the go on the driveway, easy job! 2011 Vogue 4.4 TDV8
17th Mar 2024 7:34pm |
Many thanks Mr Tom, I'll have a look there. |
18th Mar 2024 11:06am |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 145 |
I have this No DAB issue too, but also have a crackly phone signal and weak FM signal which gets worse when the heated rear window is on. Can anyone recommend a fix for this please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
18th Mar 2024 9:10pm |
Replaced the DAB module in the boot, all good now ππ» Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
6th Apr 2024 4:25pm |
Strawman Member Since: 13 Aug 2023 Location: Scotland Posts: 1 |
No DAB radio check this out from about 5:50 worked for me on my 2011 4.4 same problem worth checking as its cheap.
16th May 2024 12:57pm |
