Home > My Range Rover > My first Range Rover some advice please |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
L322 are not high end enough for them Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Feb 2024 10:07am |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 138 |
Thank you for all your help thus far. The car drove well on the way home with only a couple of issues. The DAB part of the system does not pick up any stations, TV, Radio, Nav all working fine. Is this a common issue and any pointers here please, it has stations in memory but seems like there is no aerial reception.
18th Feb 2024 3:02pm |
DAB is crap. I use FM
18th Feb 2024 6:19pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
Never had a problem with the DAB apart from poor coverage in some rural areas. Get the sender fixed as if it fails and falsely reports an empty tank it shuts the engine down. Also DPF regeneration won’t happen if the ECU thinks the tank is less that 1/4 full. 2012 TDV8 Vogue (L322) |
18th Feb 2024 6:23pm |
Many Thanks |
18th Feb 2024 9:46pm |
A few photos of the car
20th Feb 2024 8:26am |
Can anyone recommend a reasonably priced good independent specialist close to Basildon in Essex please. Ideally one that you have personal dealings with, many thanks. |
20th Feb 2024 8:35am |
This place has a good reputation on these forums.
20th Feb 2024 8:53am |
Thanks that was mentioned earlier will give them a go I think |
20th Feb 2024 10:30am |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 216 |
Search for danielB on here, he does cd changer repairs. Definitely recommend, based in Bishop Stortford.
20th Feb 2024 10:06pm |
As previously stated: Call Martin Hind at Dartford Transmissions and Autocare. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
21st Feb 2024 11:34am |
Thanks I have sent Daniel a PM |
21st Feb 2024 7:55pm |
Am I missing something here?
23rd Feb 2024 10:29am |
The detachable tow bar fits in there.
23rd Feb 2024 10:53am |
