Home > My Range Rover > My first Range Rover some advice please
Page 3 of 5 <12345>
DrRob
L322 are not high end enough for them Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685898 18th Feb 2024 11:07am
JayGee
Pro theives are not interested in a +12 yr old car and the OE security is adequate for opprotunists.
First thing to do when you get it is to have it inspected by a specialist LR garage ( Not main dealer) so you know about any issues and if you have bought it from a dealer you can get them rectified and if they are serious get your money back. 2nd thing to do is to by yourself a GAP IID tool so you can do your own diagnostics and calibrate and reset things like suspension, batteries etc as this will save you multiple times the cost over garage diagnostic fees. 2012 TDV8 Vogue (L322)
Post #685904 18th Feb 2024 12:02pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Thank you for all your help thus far. The car drove well on the way home with only a couple of issues. The DAB part of the system does not pick up any stations, TV, Radio, Nav all working fine. Is this a common issue and any pointers here please, it has stations in memory but seems like there is no aerial reception.
Also the fuel gauge is showing very low, put £60 diesel in showed less than a quarter, I'm thinking it should be around half. It was a private sale BTW. The guy did say as I was leaving that sometimes if you fill the tank it only shows half full but not always.
Said a wire in the tank might be an issue? I suspect sender unit maybe? Any pointers on these two issues please.
Suspension moves as it should with no noises, had drop links 7k ago, oil cooler 11k ago, brakes all round discs and pads in 2019 along with both rear shocks, also gearbox oil and filter16k ago along with normal service items
Awesome bit of kit though, very happy on day one!
Post #685915 18th Feb 2024 4:02pm
DrRob
DAB is crap. I use FM
There is known in tank wiring issue. A good specialist can fix it. Have a search on here.
Enjoy it 🤙 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685923 18th Feb 2024 7:19pm
JayGee
Never had a problem with the DAB apart from poor coverage in some rural areas. Get the sender fixed as if it fails and falsely reports an empty tank it shuts the engine down. Also DPF regeneration won’t happen if the ECU thinks the tank is less that 1/4 full. 2012 TDV8 Vogue (L322)
Post #685924 18th Feb 2024 7:23pm
Buellie
Many Thanks
Post #685931 18th Feb 2024 10:46pm
Buellie
A few photos of the car
Post #686028 20th Feb 2024 9:26am
Buellie
Can anyone recommend a reasonably priced good independent specialist close to Basildon in Essex please. Ideally one that you have personal dealings with, many thanks.
Post #686030 20th Feb 2024 9:35am
JayGee
This place has a good reputation on these forums.
www.dartfordtransmissions.co.uk 2012 TDV8 Vogue (L322)
Post #686032 20th Feb 2024 9:53am
Buellie
Thanks that was mentioned earlier will give them a go I think
Post #686042 20th Feb 2024 11:30am
Sonearly
Search for danielB on here, he does cd changer repairs. Definitely recommend, based in Bishop Stortford.
Group 1 automotive, Progress Road, Leigh on Sea is highly thought off.
Post #686108 20th Feb 2024 11:06pm
DrRob
As previously stated: Call Martin Hind at Dartford Transmissions and Autocare. Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686126 21st Feb 2024 12:34pm
Buellie
Thanks I have sent Daniel a PM
Post #686160 21st Feb 2024 8:55pm
Buellie
Am I missing something here?
Post #686272 23rd Feb 2024 11:29am
DrRob
The detachable tow bar fits in there.
I removed that foam insert (Two bolts hold it in) and now have a much larger storage area as I don't use the towbar at all so not needed. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686273 23rd Feb 2024 11:53am
Page 3 of 5 <12345>
