![]() | Home > My Range Rover > My first Range Rover some advice please |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
L322 are not high end enough for them |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 153 ![]() ![]() ![]() |
Thank you for all your help thus far. The car drove well on the way home with only a couple of issues. The DAB part of the system does not pick up any stations, TV, Radio, Nav all working fine. Is this a common issue and any pointers here please, it has stations in memory but seems like there is no aerial reception.
DAB is crap. I use FM
Never had a problem with the DAB apart from poor coverage in some rural areas. Get the sender fixed as if it fails and falsely reports an empty tank it shuts the engine down. Also DPF regeneration won’t happen if the ECU thinks the tank is less that 1/4 full. 2012 TDV8 Vogue (L322) |
Many Thanks |
A few photos of the car
Can anyone recommend a reasonably priced good independent specialist close to Basildon in Essex please. Ideally one that you have personal dealings with, many thanks. |
This place has a good reputation on these forums.
Thanks that was mentioned earlier will give them a go I think |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Search for danielB on here, he does cd changer repairs. Definitely recommend, based in Bishop Stortford.
As previously stated: Call Martin Hind at Dartford Transmissions and Autocare. ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks I have sent Daniel a PM |
Am I missing something here?
The detachable tow bar fits in there.
