Home > My Range Rover > My first RR a 2013 Vogue SE
Page 4 of 6 <123456>
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I may have found the source of the coolant leak. What is this part? Thanks Thumbs Up
Post #685842 17th Feb 2024 10:04am
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I think it is Part Number: LR023142 but there is a good chance you cracked it when you removed the doughnut as it goes very brittle with age
Post #685855 17th Feb 2024 12:18pm
Richie N
Thanks 👍 ordered.
Post #685861 17th Feb 2024 1:51pm
Richie N
I have to say the oven cleaner appears to be the way to go with cleaning the intake.
I tried my first ever oil change today without getting under the car. It was slow going as the oil was cold, but I’m impressed, the kit sucked 9 litres out (that’s the max capacity). I’m tempted to leave it at that and do another change in 3k miles.
Post #685867 17th Feb 2024 3:19pm
JamboM3
How long did the oven cleaner/cleaning part take? And what did you do with the mess after
Post #685878 17th Feb 2024 6:21pm
Richie N
Okay so I have used nearly 3 tins of oven cleaner. I’ve probably done 6-8 applications over a couple of days. Gave a good coat, leave for 30 mins to soak, then agitate for 5 mins with the radiator brush, before rinsing with a hose. Repeat..
I would say at least 80% of the soot/residue has been removed.
Post #685879 17th Feb 2024 7:43pm
TJNZ
New Zealand 2017 Range Rover Autobiography SDV8 Carpathian Grey
Props to you for giving it a go, your obviously very handy. I bought my 2017 4.4 SDV8 almost 2 years ago. It had been imported from the UK by an independant dealer here in NZ and I traded my 2015 RRS SCV8 on it. Its had some of the usual problems including the oil cooler and transfer case which both have been replaced under warranty. I have also had all the fluids changed diffs, transmission etc so it has a good start in my ownership. I have enjoyed doing some minor mods - mudflaps, side steps, 20inch LR rims sparayed and now fitted with AT tyres plus other bits and pieces. It has cost a bit but I really love the car and a superb tourer. Great job with the repairs I hope it will be a fantastic car for you! 2017 L405 AB SDV8
2011 L322 Vogue SE 4.4 TDV8
Post #685882 17th Feb 2024 8:48pm
Richie N
Thanks 👍 I’ve always loved taking things apart since I was a kid.
I know what you mean and I’ve only had the car a month! It appears most people who love the cars are prepared to accept the faults, it’s a small price to pay 😀
Post #685891 18th Feb 2024 8:07am
Richie N
A bit more cleaned and refitted today. Hopefully I’ll finish it in the morning. Throttle body cleaned up well.
Post #686305 23rd Feb 2024 6:03pm
Richie N
All buttoned back up. Test drive done and all seems good 👍 Even the DPF nearly full warning light went out after a quick, sixth gear run down the m/way. Hopefully I can enjoy it for a while now! Wink
Post #686343 24th Feb 2024 11:57am
JamboM3
Satisfying to see it all clean!
Any noticeable improvement to throttle response? I had this done on my L322 but haven't inspected current l405
Post #686438 25th Feb 2024 4:31pm
Richie N
I can’t say to be honest as I’ve only owned the car two weeks before I did the work. But I would say it runs sweet, a really nice idle etc so cleaning it out can only improve it 🤷‍♂️
Post #686442 25th Feb 2024 5:00pm
Richie N
I hate having to slam the bonnet shut so I ordered a new alarm switch to see if that fixes it.
Well it did and it didn’t. Initially on installation I still had to slam the bonnet a bit. Then I decided to adjust the position of the lock mechanism and that seemed to do the job. So did it need a new one 🤷‍♂️ the old one looks very crusty so probably a good idea anyway.
Post #686970 2nd Mar 2024 3:41pm
JamboM3
This is useful! I have to slam mine and the noise is god awful, always liked the click/push to latch on my L322, thought this was a feature not a bug!
Will have a look and see if I can adjust it myself
Post #687221 4th Mar 2024 9:01pm
Richie N
Worth a look. I’ve also noticed my bonnet is higher on the switch side of the car - the panel gap is much bigger. So perhaps the bonnet alignment needs adjustment, which will bring the loop down lower into the latch- which would make sense.
Post #687222 4th Mar 2024 9:18pm
