![]() | Home > My Range Rover > My first RR a 2013 Vogue SE |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
That’s a good question that I have heard many times. Basically, the dealer asked me to drive it back to them, 30 miles around the m25. If they were happy for me to do that I didn’t fancy trusting them to do the repair properly - I wasn’t too keen on my local garage doing it either.
I can see why this costs £1k. The rear pipe into the cooler had been leaking previously. It had a bodge done on it with some sealant.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 515 ![]() ![]() |
Good for you, you clearly have a decent level of competance with the spanners! |
Thanks Jon, I’m going to change the oil anyway.
plees23 Member Since: 03 Jun 2023 Location: Leyland Posts: 43 ![]() ![]() ![]() |
At least doing the job yourself you know how it’s been done and no corners have been cut. 10/10 for having a go and taking it on! |
Cheers |
Onwards and upwards. Changed the water pipe on rhs of the cooler, and put new viton o rings in the feed to the rear of the cooler. Cleaned up mating surface and installed new cooler..
recordman Member Since: 08 May 2013 Location: Kent Posts: 117 ![]() ![]() ![]() |
Exquisite looking job there Richie, well done |
Thanks 👍 it’s slowly getting there. |
The bolt that holds the feed pipe at the rear of the cooler has me beat! 🥵 the bolt will not go in and I can’t see the hole. I’ve decided to fit a stud and nut instead.
Where there’s a will. I cancelled my order for some M6 stud screws, and made one out of a cut down bolt. Worked a treat. I recommend fitting a stud before fitting the cooler for anyone doing this - it is much easier.
Today it was on to a job I was not looking forward to, cleaning the intake!
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 136 ![]() ![]() |
Good Job |
Thanks |
