Home > Technical (L322) > Front Blowers and FSR - Next Steps? |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 25 |
Hi, lots of info on site. Normally a motor problem. There is a really good descriptive procedure on here, it may be in WIKI. For the cost of a motor, I'd just replace. I believe there is a BMW alternative at decent prices |
12th Feb 2024 6:13pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
Bite the bullet and get a new fan installed
12th Feb 2024 6:15pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 71 |
Cheers guys, yes cheap though I think it will take me significantly longer than 5 hours!
12th Feb 2024 6:34pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1372 |
When this happened to mine there was also a need to free up and lubricate the moving parts that direct where the heated air goes, sorry to be so non-technical in the description. Only Range Rovers since 1988 |
12th Feb 2024 7:23pm |
Thanks CS, the duct actuators(?) seem to be working fine at the moment, however while I am in there it sounds a great idea to lubricate as well. What did you use, silicone grease? |
12th Feb 2024 7:46pm |
It was done by the dealers, so I'm not sure, sorry. Only Range Rovers since 1988 |
12th Feb 2024 7:51pm |
