Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs?
Page 4 of 4 <1234
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
LEDs arrived today from Bevinsee for the D3S headlamp and H7 high beams.
I'm familiar with replacing the D3S in-situ (insert first, then connect the plug), but haven't any experience with the high beam H7's. Is there a similar order of operations trick to them? (And is there a retainer clip?)
 2012 Supercharged L322
Post #683272 20th Jan 2024 12:17am
kevinp
I've just put some H7 LED's in mine and they just pull out. Just make sure the 'tang' on the bulb is pointing down so that it fits in the slot of the bulb holder and that none of the wires get in the way to seat it properly.
Look through the headlamp to see the position of the old bulbs first before taking them out because when you put the new bulb in it never feels as though it seated properly in my experience.
I found it easier to have the power lead connected to the bulb before fitting. Thumbs Up
Post #683286 20th Jan 2024 8:28am
DrRob
Push fit only. No need to turn it. As above, line up the tab.
I noticed the LED is at an angle when looking from the front but no impact on performance.
Enjoy a brighter life with your new bulbs Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #683293 20th Jan 2024 9:38am
JayGee
Can't remember any issues fitting mine as they have the same fitting. 2012 TDV8 Vogue (L322)
Post #683311 20th Jan 2024 12:52pm
Page 4 of 4 <1234
