Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs?
Page 1 of 4 1234>
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
Thinking about giving these a go in my main beams on my 55 plate L322.
Has anyone here tried them or anything similar?
https://rover.ebay.com/rover/0/0/0?mpre=ht...2935954895
Post #539269 3rd Jan 2020 6:06am
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I haven't tried those but you can't fit any with a fan or heatsink on the back.
Those should fit I think.
Post #539273 3rd Jan 2020 9:05am
jim4244
Yes I’ve seen the ones with the small fan and they look too big.
These appear to be the same size as the original bulbs.
Jim
Post #539276 3rd Jan 2020 9:11am
Quote from listing:
Used for Daytime Running Light, Fog Light ONLY. (These bulbs are not suggested to be used as headlights, no high/low beam function)
Question .
Post #539280 3rd Jan 2020 10:02am
I have some led bulbs with the rear rather bulky fans fitted to my secondary main beam headlights.
Granted they are difficult to fit but not impossible, it means taking the headlight off the car to fit them.
The light output is very impressive, had them on a couple of years now so probably due to fail soon.
Would definitely fit similar again.
Post #539291 3rd Jan 2020 12:31pm
gilesharrison
Did you modify the metal clip that holds the bulb in to the housing?
Post #540082 10th Jan 2020 8:18pm
Ive used the type with the aluminium webbed rope cooling strips on many different applications...
And they work brilliantly! Especially in high beam applications...
That said! They are now frowned upon by the MOT industry... Rolling Eyes
Post #540084 10th Jan 2020 8:25pm
gilesharrison
Have you got a link to anything, Craig?
I'd like the brightest possible on my 2008 TDV8.
Post #540085 10th Jan 2020 8:34pm
Didn't need to modify it, but I did take it off and repositioned it, I think I moved it through 180 degrees from memory. As I said difficult to fit but not impossible.
Post #540102 10th Jan 2020 10:28pm
These are the type i have used... Not from this seller, but you get the idea sir... Thumbs Up
https://www.ebay.co.uk/itm/6B00-White-H7-6...SwQY9eFIqP
Post #540129 11th Jan 2020 12:58am
gilesharrison
Thank you Craig.
I got some bulbs a bit similar to that but with more of a heat sink or the back, not the metal braided wire.
Problem was, I couldn't work out how to get them to stay in the light enclosure. The metal retaining clip which is use with a normal halogen bulb wouldn't fit over the back of the led bulb.
Post #540141 11th Jan 2020 9:09am
Often the plastic part of the LED bulb, the bit that takes the shape of the original bulb securing/locating ring turns 45/90 degrees and slides off! This allows you to fit the holder, then fit the bulb with a quarter/half turn to lock it in place sir... 👍
Post #540146 11th Jan 2020 9:43am
gilesharrison
Thanks for that Craig. Very thick of me not to notice that the plastic bit comes off. Still not sure they'll fit though.
Post #540396 13th Jan 2020 9:05am
jim4244
Hi all
Back in the UK now so just fitted these LED bulbs to Sylvia. Fitting was very easy, just a straight swap and to make things easier I removed the complete headlight unit so all in all around about a 25 minute job.
Much whiter and no error messages on my 55 plate TD6.
I’ll test them out tonight when I go to pick up the weekend Chinese. 20 miles mostly on unlit country lanes. I report back tomorrow.
£11.39 off EBay
Before with standard H7’s
Halfway
Finished
Jim
Post #540975 18th Jan 2020 11:31am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Any body seen jim4244, said he was going to report back on these led bulbs hope they didnt fail on him and he missed that corner or the car broke down (other options are available).
Post #541129 20th Jan 2020 1:56am
Page 1 of 4 1234>
