Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3172 |
I would also need to buy a new HID bulb and not the old faded bulbs I replaced - not going to happen. 2012 TDV8 Vogue (L322) |
16th Jan 2024 9:31am |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
I'm surprised you need to ask - if you get excessive glare the pick any one of the three. |
16th Jan 2024 12:04pm |
You won't - because if an oncoming driver does have an issue with glare from LED lights and "flashes" they get a return retina burning flash back. |
16th Jan 2024 12:07pm |
There are no optics in the bulbs it's just a light source - the optics are in the headlight housing The LED light source is in the same place withing the lights optical system as the HID light source What is unsuitable again? 2012 TDV8 Vogue (L322) |
16th Jan 2024 12:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35246 |
this is my test setup..led is on the right of the pic , xenon on the left..
16th Jan 2024 1:09pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1202 |
I've just fitted some Bevinsee DS3 bulbs and I'm not sure which High beam bulbs I need to match them.
16th Jan 2024 2:15pm |
I fitted these
16th Jan 2024 2:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7774 |
I also bought the above. No faults on the dash though, no problems so far..
16th Jan 2024 2:47pm |
Doesn't show a fault on my dash either - only on the GAP IID fault code scan. 2012 TDV8 Vogue (L322) |
16th Jan 2024 4:44pm |
Thanks very much for the info. Going for a drive now to see if the new D3S light up the countryside. |
16th Jan 2024 4:53pm |
I am now an LED convert as well. Amazing difference. Going to order the high beam bulbs now. Thanks for the advice. |
16th Jan 2024 7:44pm |
The fact that the optics were not designed for the LED light source. |
17th Jan 2024 10:49am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 534 |
Modern LED's have the light source in exactly the same place as in the bulb they are replacing. It is also a smaller source than either halogen or HID, hence the tighter beam pattern noted in Stan's post.
17th Jan 2024 12:25pm |
The LED light source was designed for the optics and works as intended to produce the correct beam pattern. No idea why you are struggling with this..... 2012 TDV8 Vogue (L322) |
17th Jan 2024 4:19pm |
