Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs?
Page 3 of 4 <1234>
GraemeS
SamThomas wrote:
Even in the image you can see a little more glare from the LED...........
The picture has been taken standing to the left of the light with the LED globe where the cut-off rises, but standing to the right of the HID globe where the cut-off is horizontal. To get a proper comparison, take a picture standing to the right of the LED globe to compare its glare with the HID in this picture.
Post #682844 16th Jan 2024 9:17am
JayGee
I would also need to buy a new HID bulb and not the old faded bulbs I replaced - not going to happen. 2012 TDV8 Vogue (L322)
Post #682846 16th Jan 2024 9:31am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
JayGee wrote:
In what ways exactly are the optics poor, mismatched and unsuitable ?
I'm surprised you need to ask - if you get excessive glare the pick any one of the three.
Post #682855 16th Jan 2024 12:04pm
SamThomas
DrRob wrote:
I'd never go back to old skool bulbs now. Never had anyone flash me on dipped. All good Thumbs Up
You won't - because if an oncoming driver does have an issue with glare from LED lights and "flashes" they get a return retina burning flash back.
Post #682856 16th Jan 2024 12:07pm
JayGee
There are no optics in the bulbs it's just a light source - the optics are in the headlight housing
The LED light source is in the same place withing the lights optical system as the HID light source
What is unsuitable again? 2012 TDV8 Vogue (L322)
Post #682859 16th Jan 2024 12:17pm
this is my test setup..led is on the right of the pic , xenon on the left..
as you can see the beam is more crisper than the xenon.
Post #682864 16th Jan 2024 1:09pm
kevinp
I've just fitted some Bevinsee DS3 bulbs and I'm not sure which High beam bulbs I need to match them.
Can some kind person send me a link as to which ones to buy please because some seem to have fans, ballasts or just ordinary H7 plug in types.
Post #682877 16th Jan 2024 2:15pm
JayGee
I fitted these
https://www.ebay.co.uk/itm/371786510808
They do throw a fault code when you do a GAP IID scan and there may be other ones from Aliexpress that Sam's motors linked. 2012 TDV8 Vogue (L322)
Post #682880 16th Jan 2024 2:23pm
mjdronfield
I also bought the above. No faults on the dash though, no problems so far..
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #682883 16th Jan 2024 2:47pm
JayGee
Doesn't show a fault on my dash either - only on the GAP IID fault code scan. 2012 TDV8 Vogue (L322)
Post #682899 16th Jan 2024 4:44pm
kevinp
Thanks very much for the info. Going for a drive now to see if the new D3S light up the countryside.
Post #682900 16th Jan 2024 4:53pm
kevinp
I am now an LED convert as well. Amazing difference. Going to order the high beam bulbs now. Thanks for the advice. Thumbs Up
Post #682922 16th Jan 2024 7:44pm
SamThomas
The fact that the optics were not designed for the LED light source.
Post #682977 17th Jan 2024 10:49am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Modern LED's have the light source in exactly the same place as in the bulb they are replacing. It is also a smaller source than either halogen or HID, hence the tighter beam pattern noted in Stan's post.
If there were any light scatter, Stan's fence photo would show it. In fact it's less. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #682988 17th Jan 2024 12:25pm
JayGee
The LED light source was designed for the optics and works as intended to produce the correct beam pattern. No idea why you are struggling with this..... 2012 TDV8 Vogue (L322)
Post #683014 17th Jan 2024 4:19pm
Page 3 of 4 <1234>
