Home > General > What Did You Do In Your Full Fat Today
Page 367 of 379 <123 ... 366367368 ... 377378379>
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Yes, I should have done that at the time so I don't have any pictures so I'll try to put into words.
The leading edge of the roof, ( in fact the full length is but I was only interested in the front section) is held on by 2 of these clips, 1 on each side.
https://www.ebay.co.uk/itm/155961443052?ch...gLaIPD_BwE
But you cannot access the screw that secures it except from below, behind the headliner. If you can visualise the screw going upward from within the car, through the roof and securing the clip in place outside the car.
So I prized off the leading edge piece from the rest of the trim, it's about 6" long, and using a twisting motion seprated it from the rest of the trim that runs the full length of the roof. Removed the broken remains of the broken white clip from the trim piece and also the circular centre which was itself still stuck to the screw on the roof section, the little wiggly bits had sheared off.
I popped off the broken clips (take care to note the orientation as they can go one of 4 ways) and carefully put the replacements into the trim, refitted the front 6" trim to the main trim (very fiddly, push twist, push twist other way etc. etc.), then by carefully trying to line up the round center of the clip with the now exposed screw head pushed the trim piece lower it down and once in place press quite firmly but not so hard as to push the screw back through the roof.
Luckily it popped on both sides without too much effort very close to flush.
If I had the time it would have been better to drop the headlining and tighten the screws fully from the inside again but it's quite secure with no movement so I didn't bother.
Clips, £7 each I bought a few as I expected to break some, but in the end only broke 1.
Hope this helps.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #682251 9th Jan 2024 3:06pm
AlexTVR
New Wheel nuts and Centre caps on the new to me RR. Getting to understand why my posts are being deleted too Wink 2010 Supercharged
Post #682259 9th Jan 2024 4:15pm
rainking
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Today was/is MOT day for mine.... passed without issue Very Happy
Can't believe I've had the 405 2 years already Shocked Andrew.
Post #682323 10th Jan 2024 12:16pm
Superspoons
Drove past here on Sunday after a weekend away in the Cotswolds, so rude not to take a snap... no sign of Jeremy or the L322 Smile
 Gavin
https://www.youtube.com/@ChallengingClassics
Post #682342 10th Jan 2024 4:02pm
AndyRoo
3 months now after pulling the fuse for auto wipers, no problems at all, much less frustrated and change has proved uber reliable using adjustable intermittant wipersI just drive with lights on all the time "Auto", they still turn off with the ignition, so all good.
Pressure washed all the fresh oil off the under belly, will get around to trying to resolve that as soon as the O rings turn up, thanks Ajmngn for the tip.
Post #682500 12th Jan 2024 12:29pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Came back from Switzerland (Haute Nendaz) yesterday after a week of skiing.
Was about 1000 Mile round trip and the Fatty performed very well!
The new front brakes are well bedded in and work well. (Bosch discs and pads)
One thing I did notice was that when setting off home bound the temperature gauge fluctuated a little between 1/4 to 1/2 way on the scale so I'm thinking my thermostat plus housing needs renewal but we'll see how it goes.
Didn't get any snow under the new Pirellis but they did save on fuel !
Pictures to follow once I figured out some hosting for them.
Cheers, Ard
Edited for the 19th time in the hope I get you to see some pictures ! Confused
Post #682576 13th Jan 2024 9:08am
AndyRoo
Replaced the two BS611 oil rings due to leak this morning, old ones were hard and crusty, 1 broke removing it, hopefully all good now.
Off to Tewkesbury Rugby later so will see if any dripping on my return, Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #682664 14th Jan 2024 10:08am
Rex the RR
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Santorini Black
Exchanged my 2011 4.4 tdv8 vse of 10 good years for a 2021 p525 AB. Only doing short journeys now so back to a petrol!
Post #682827 15th Jan 2024 8:57pm
MC-RR
Monaco 2012 Range Rover HSE 4.4 V8 Ipanema Sand
Differentials and transfer box oil change
Hello to all.
Finally got all the materials to do the front and rear differentials as well as the transfer box oil change.
Land Rover dealership in the south France are totally ridiculous with their pricing.
Anyway, was waiting for the 500cl syringe and 14mm allen key needed for the front diff to get started.
Since "The Beast" just reached 145000Km (90K miles?) was definitely time to get fresh oil in her.
Was surprised how straight forward and rewarding (fun) the job was. Hardest part was raising the beast enough to slide under to reach the diffs and transfer box. RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Triumph TR6 1976 - Jeep CJ7 1976
Post #684142 28th Jan 2024 7:48pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
MOT time, passed with a couple of minor advisories that I’ll sort out when it gets a bit warmer. I guess I’ll be keeping it for another year at least then Bow down
Post #684450 31st Jan 2024 6:18pm
RobErica
Netherlands
Finally gave myself the time to check the little rumble that i felt for a while now. Had my suspect, and now i have certainty.
Checking for a new bearing and time.
That is all for today
Post #684667 3rd Feb 2024 11:59am
AndyRoo
Replaced rear anti roll bar rubbers, took the opportunity to mist spray entire rear subrame & chassis with Nitomors & then Dintrol.
Working my way around the car front subframe area yesterday. sills & arches when weather improves.
Post #684714 4th Feb 2024 11:17am
JoolsB
Found some paint bubbling under the rear tailgate lid, not too bad so I think I will try some stuff to hold it at bay for a couple of years. Had a good look at the wheel arches when I found it, but they look ok
I think with a bit of treatment the tailgate should last as long as I plan to keep the car.
Post #684746 4th Feb 2024 8:19pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Did 15 miles of off road driving in Mid Wales. And pulled two fallen trees out of the way.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #684747 4th Feb 2024 8:33pm
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
Changed the ARB bushes, easy job on the drive with some 3t vehicle ramps. The old ones were fitted by the dealer 18months or 10k miles ago. They didn't look worn but the ARB was fairly easy to move, and once the brackets were off the sub frame they were definitely loose. I used genuine bushes with a receipt from the dealer so that if the ARB seals go they can't say it is due to me using non-genuine parts. I'd be interested to hear what aftermarket bushes others use.
Post #684750 4th Feb 2024 9:24pm
