![]() | Home > General > What did you buy for your FFRR today? |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
It's now been three weeks (tomorrow) since I picked the car up. Been using it non-stop in the last week, so all my tinkering was in the first 2 weeks...
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 48 ![]() ![]() ![]() |
4 new tyres 👍🏻😎
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 453 ![]() ![]() |
A new water pump! Prevention better than the alternative, it had chirped a couple of times while on tour, 4hrs labour to fit.
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 67 ![]() ![]() ![]() |
Replaced the heater control valve. Thought I had fixed the old one before summer but nay...cold feet on the first motorway run of the autumn.
May have popped out of it's holder when I removed the panel.
You can see where someone has been here before and trapped some of the wires across the vent. In any case re-secured cable and put it all back together, securing the loose wiring first.
Right result - warm feet. 2007 3.6 TDV8 1979 Mini Special 1988 Yamaha FJ1200 !952 BSA Gold Flash |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
Bought 2 wheel bearings, 2 Front suspension arm kits and 2 wheel sensors, spent some considerable time and effort changing the bits, even bought an impact wrench to speed things up, painted all bits, all works fine now and looking at the old suspension arms it was about time that it was done.
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
A nice 5 tonne SWL German bottle jack; my Sprinter Jack was leaking and it was cheaper to buy a new jack than get the old one repaired. 😣 L322 TDV8 4.4 - current
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
Today I did my first top engine oil change and I will never look back. I couldnt find the draper everyone else uses so had to buy the Draper 81315 and technically use it wrong but it did the job, sucked out all the oil and no mess, love it.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Got my new front brake discs in today. GOOD GRIEF ! They're heavy !!! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Looked out the window at mine today but having covid over Christmas means ive not been anywhere in her for ten days now... |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
I could tell you wasn't well Craig about the Battery comment |
Good tyre choice Edgey. ![]() |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
New 20 tonne bottle jack, don't trust the scissor jack and my old bottle jack leaking now. Took a bit of fettling to cut back the tapered right hand boot cubby to accomodate the wider base.
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
New front discs, callipers and pads. Now just need a dry day to get them fitted! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
@nobby
