Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 110 |
Great thread and very helpful as I need to do a full service on mMy newly acquired 2012 Westminster TDV8.
6th Sep 2022 1:23pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
I'd avoid cheap unbranded pumps - my experience is that the vacuum quickly fails. Not experience of this pump but of two different types I've purchased before.
6th Sep 2022 2:36pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3200 |
You can also use an electric pump to extract the oil and someone had a post about this a while back as it was quite a bit cheaper. 2012 TDV8 Vogue (L322) |
6th Sep 2022 3:46pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 187 |
Hi guys
19th Dec 2023 10:11am |
It's Petronas 5000 FJ 5W-30 for the 4.4 TDV8 (quite cheap as a 10L kit from Opie Oils - there's usually also a discount code).
19th Dec 2023 1:39pm |
Thanks for the info Gary
19th Dec 2023 9:38pm |
Using the Draper tool is really easy. You can crack on with changing the oil filter and any other service parts whilst it's draining.
19th Dec 2023 9:45pm |
drphilgarner Member Since: 20 Sep 2022 Location: Lancaster Posts: 32 |
I used an electric 'Ultimate Speed' pump I bought from LIDL a few years ago. Worked fine and got plenty of oil out. 2011 4.4 TDV8 Vogue |
21st Dec 2023 6:20pm |
I tried the Sealey 12V one and it was useless. Not enough power to suck oil out of an engine. 2015 Range Rover Autobiography 4.4 SDV8 |
21st Dec 2023 9:40pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I use one of the 12V oil extractor pumps off ebay. Has plenty of suction and has done the job perfectly well each time. I normally connect a battery charger to the +VE and ground posts in the engine bay, and then the pump's croc clips onto the same posts. Seems to ensure the best power for the pump. I pump the old oil out into an old 25l oil canister on the ground.
21st Dec 2023 11:58pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 183 |
A question on this that has been troubling me (why I think about these things I do not know), I see that there are mostly 9L extraction pumps that are a reasonable price (I am not opposed to buying the 10L Draper one mentioned in the post) but I was just wondering how people handle the pump getting full?
14th Mar 2024 5:17pm |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 70 |
I use a 30l camping water container to decant it into, so only one-third the number of trips to the local tip for disposal. 2012 TDV8 Westminster in the New Forest
14th Mar 2024 5:45pm |
Thanks Shaun, that is a good idea. |
14th Mar 2024 5:50pm |
You can disconnect the extraction tube once 9L has been removed (if you have a 9L pump, you can then empty and do the next bit. This is a bit of a faff though, so it"s probably best forking out for the 10L). But otherwise just keep a spare empty 5L washer fluid container for waste oil. By the time you've done 3 or 4 oil changes, on the next one you need only buy 5 litres.
14th Mar 2024 6:14pm |
