![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
You won't regret it |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
So I've just bit the bullet after a few years of 2010 TDV8 4.4 ownership and splashed on a new Gap Tool.
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
RB
More bizarre from IID
Normal 2012 TDV8 Vogue (L322) |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
I have a non BT iid, for the 2003 RR and wondering if there is an upgrade to a Bluetooth version for mine.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
i dont think there is ..
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
Is there a way to turn the ignition on in a 2012 L322 to get the full IID capability without running the engine? |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 216 ![]() ![]() ![]() |
Press the stop start button without your foot on the brake. I presume that’s what you mean by your question. |
Thanks Pete, yeah that's exactly what I meant, worked a treat 👌
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 139 ![]() ![]() ![]() |
I have to pull my door handles twice to get out (2011 4.4) can this be changed to single pull with the IID? I’ve looked but there’s nothing obvious 1972 Series 3 full of character
BigEnglishWagon Member Since: 30 Jun 2020 Location: Wellington Posts: 11 ![]() ![]() ![]() |
Press the Unlock button on the centre dash near the Hazzard Flash button. All doors then are unlocked. Try it. |
sounds like you have drive away locking enabled ..this requires a double pull to open the doors..
