Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 47 of 49 <123 ... 46 474849>
Yes, thanks.
Checked with Patrick and he confirmed it has to be G3. Luckily another forum member less than half an hour from me was selling one, so I'm all sorted Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #680144 12th Dec 2023 3:46pm
JayGee
You won't regret it Thumbs Up 2012 TDV8 Vogue (L322)
Post #680160 12th Dec 2023 5:35pm
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
So I've just bit the bullet after a few years of 2010 TDV8 4.4 ownership and splashed on a new Gap Tool.
I'm sort of thinking now that ignorance was bliss.
Now, the battery is a bit sleepy (11.5v at rest with ignition on). I have a new Bosch AGM one to fit once I've sussed out the Gap Tool a little more.
1. AHCM shows as not fitted. Really? I definitely have one. Any suggestions? Fuse obviously but other suggestions welcome.
2. Looking for heated/cooled seats as they don't work. No CM. No faults. Fiddle a bit with controls. Get CM and faults which as expected were one seat with a dodgy seal and the other with dodgy temp measurement. No CM available in Live Data. Any hints to bring up live data?
Thanks in advance. I am sure this is only the beginning. 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #680165 12th Dec 2023 5:57pm
RiverBlanche
Hi,
MC, think the best check for the battery is when the car is "Fully" asleep and then check the Voltage,
if you have tow electrics the socket gives very easy way of checking.
Alanm, are you planning on getting a L405, Question
if so I would suggest NOT to try and clear any faults Unless you have already bought it,
think if someone just before you viewed the car and had cleared any faults showing as a gesture to the seller Shocked you then find NO faults.
Post #680171 12th Dec 2023 6:49pm
mcspreader
RB
Many thanks. I'll be changing the battery on Saturday so not too worried and I have a battery condition analyser which says it's knackered.
The tow electrics trick is handy though if you can't access the vehicle. 2011c Vogue SE 4.4 Oil Burner
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #680235 13th Dec 2023 5:31pm
mcspreader
More bizarre from IID
Tells me I have a 6-spd TCM and the 8-spd is not fitted. On an 11MY TDV8? Is this normal?
Hint: it is defo an 8-spd. 2011c Vogue SE 4.4 Oil Burner
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #680344 14th Dec 2023 5:42pm
JayGee
Normal 2012 TDV8 Vogue (L322)
Post #680346 14th Dec 2023 5:59pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I have a non BT iid, for the 2003 RR and wondering if there is an upgrade to a Bluetooth version for mine.
I see on the Gap web site the old version is now no longer to buy. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #680424 15th Dec 2023 9:00pm
i dont think there is ..
you could sell yours and buy a BT one. ... - .- -.
Post #680428 15th Dec 2023 9:55pm
RovingCanary
Is there a way to turn the ignition on in a 2012 L322 to get the full IID capability without running the engine?
Post #682047 7th Jan 2024 10:56am
PeteT80
Press the stop start button without your foot on the brake. I presume that’s what you mean by your question.
Post #682060 7th Jan 2024 2:19pm
RovingCanary
Thanks Pete, yeah that's exactly what I meant, worked a treat 👌
Cheers
Post #682073 7th Jan 2024 4:55pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
I have to pull my door handles twice to get out (2011 4.4) can this be changed to single pull with the IID? I’ve looked but there’s nothing obvious 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE
Post #692325 10th May 2024 10:16pm
BigEnglishWagon
New Zealand 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Press the Unlock button on the centre dash near the Hazzard Flash button. All doors then are unlocked. Try it.
Post #692342 11th May 2024 10:03am
sounds like you have drive away locking enabled ..this requires a double pull to open the doors..
have a look in the owners manual for details.. ... - .- -.
Post #692345 11th May 2024 11:00am
