Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 46 of 49 <123 ... 4546 474849>
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I was recalibrating my ride height following some work on the car, and had the same error as you.
I fixed the error eventually by killing the app on my phone, unplugging the IIDTool, then starting again. I may have reset the height via the dash controls too… but not quite sure on that bit.
I second JayGee’s comment about the guided adjustment being problematic. I had no issues with the front wheels, however the rears would not deflate. It’s possible that both down and up stop when over heating, and I didn’t realise… but had no issues adjusting the height using those dash buttons immediately afterwards.
Even the manual mode seemed to not want to lower the cars rear.
My final solution was to guess the reduction, save and exit recalibration, and finally raise and then lower the car to normal height. I got there eventually!
Lastly, don’t forget to go to service, suspension, and enable tight tolerance mode when calibrating. (And don’t forget to put it back to normal when done) Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #647504 6th Nov 2022 5:14pm
JayGee
Height calibration doesn’t need tight tolerance mode. 2012 TDV8 Vogue (L322)
Post #647528 6th Nov 2022 8:13pm
Adi322
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Gap IID Help
Just Bought a IIDBT G3 and it has given me this list of faults...
ATCM Terrain reponse
U0401-94 (2f) invalid data from engine control module- component failure- unexpected operation
U0402-94 (2F) Invalid data from transmission control module - component failure-unexpected operation
U0416-94 (2F) Invalid data from vehicle dynamics control module - component failure- unexpected operation
U0403-94 (2E) Invalid data from transfer case control module - component failure- unexpected operation
PBM Parking Brake
U0401-00 (2b) invalid data from engine control module
PCM Engine TDV8
P0088-00(2F) Fuel rail sysyem/pressure too high.
Any Ideas where to start as I am struggling with this now
Kind regards
Adi
Post #647707 8th Nov 2022 8:19pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
First clear all faults & then rescan. Wait & see if any come back, if they do, you can then google each code Thumbs Up
Post #647718 8th Nov 2022 9:17pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Re: Guided Height Calibration - error code E17
Ramblin Man wrote:
I rewatched the YouTube by Sam on this and can see what you mean by changing the ride height setting. Unfortunately I never get that far in the guided procedure due to the E17 error. I might give it another go later on today.
Here’s the link to YouTube for the benefit of anyone else trying this https://youtu.be/9ot3L4CHPd4
UPDATE Feedback from GAP says Error code E17 is due to the ECU being requested to exceed its maximum adjustment range of 250. After calibration mine was 254. The root cause is likely to be a mechanical failure of the height sensor mounts or rod.
 TDV8 4.4 2012
Post #648179 15th Nov 2022 8:32pm
Andy
I’ve just tried to test and fuel prime my FBH but I’m getting an error message E3. Anyone know what that is?
Also - whilst going through the menus, I went into calibration and found > cruise control > adaptive align. Thinking it was something that might need updating I selected it. Now I’ve lost forward alert and it’s flashing constantly on the dash. Anyone know how I can reverse this?
Thanks 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #652315 2nd Jan 2023 2:33pm
Grundey2
Even having an issue for a while, GAP IID tool gives me P0046-77.
I’ve had many suggestions from sticking actuators, faulty sensor to a leaking/split pipe on the charged side of the system.
I have spent many hours trying to find a damaged pipe, and have replaced the 4 hoses on the air intake.
How the car is driven doesn’t seem to have any resemblance on when the fault will happen, has even happened while the car is sat at idle, but it typically happens about 6 minutes into the journey and goes into restricted performance. Clearing the fault usually clears the restricted performance but still shows the fault.
I’ve had journeys where it may go into restricted performance with the red triangle 2 or 3 time over 30 miles and other times when I’ve had to reset it literally hundreds of times to clear the restricted performance.
I have tried some live monitoring, and have observed what I think is the MAP voltage (should have take a screen shot to share what I was watching) but it didn’t seem to fluctuate much under load, staying within 0.1v of 1.3v
Does anyone know if you can watch the MAP sensor, if so what I need to watch, and what the voltage should do ant idle and under load.
Post #660166 23rd Mar 2023 9:04pm
Grundey2
Post #660167 23rd Mar 2023 9:04pm
Bingo_123
anyone with a 07 tdv8 running IIDtool, need help with a default value in CCF.
Thanks
Post #672312 30th Aug 2023 11:08am
Is it still the case that you can read and clear faults on a car that isn’t registered to the tool?
I recently went to look at a L405 and when I plugged my G2 iidtool in, it connected but said “this vehicle is not registered”. I was sure this was something that worked a while back. Got - 2017 SDV8 Autobiography in Loire Blue
Post #678552 23rd Nov 2023 9:35am
i do this on my sons FF so it works for me... ... - .- -.
Post #678554 23rd Nov 2023 10:57am
Yep, it says the vehicle isn't registered but it will read and clear codes if you ask it, it's just the CCF etc that needs payment.... Thumbs Up Pete
Post #678556 23rd Nov 2023 11:14am
Ah ok, maybe I should have persevered with it, I just assumed it wouldn’t read the fault codes. I can’t remember if it gave me the option. Got - 2017 SDV8 Autobiography in Loire Blue
Post #678557 23rd Nov 2023 11:17am
Another quick question. I think I know the answer to this but wanted to be sure, is it only the G3 version that is supported for the MY17> L405? Got - 2017 SDV8 Autobiography in Loire Blue
Post #680029 10th Dec 2023 11:06pm
RiverBlanche
Hi,
there was a list on the GAP Tinternet site that gave the details of the vehicles covered by each model,
worth a check on there but ISTR something about 2017 onwards for G3.
Post #680141 12th Dec 2023 3:16pm
