![]() | Home > Technical (L322) > air suspension |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 457 ![]() ![]() ![]() |
That don’t look like the valve blocks I have on my l322….. my front and rear ones look like this
The one in the middle is next to my compressor |
Sorry just seen yours is an 2005 modal so they would be different |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
hi, that’s the best pic i seem to be able to get
can you hear your air compressor running ? |
any help would help, thanks RR 2005 4.4 petrol
Yes, the compressor is working.
I was having similar issues,after renewing the rubber seals in the valve blocks all good……try that don’t cost a lot and doesn’t take that long |
ok, will do
no change i am afraid
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
The cross-link valves in the later systems (MY07+) are a 3rd valve in each valve block, with the other 2 the corner valves.
Are your lines coloured?
LRDirect show RQT000011 superseding to RQT000013, so OK to use 13 where 11 was originally fitted.
