Home > Technical (L322) > air suspension |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 395 |
That don’t look like the valve blocks I have on my l322….. my front and rear ones look like this
10th Dec 2023 7:38am |
The one in the middle is next to my compressor |
10th Dec 2023 7:40am |
Sorry just seen yours is an 2005 modal so they would be different |
10th Dec 2023 7:49am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 737 |
hi, that’s the best pic i seem to be able to get
23rd Jan 2024 2:16pm |
23rd Jan 2024 2:33pm |
can you hear your air compressor running ? |
23rd Jan 2024 2:35pm |
any help would help, thanks RR 2005 4.4 petrol
23rd Jan 2024 2:36pm |
Yes, the compressor is working.
29th Jan 2024 5:15am |
I was having similar issues,after renewing the rubber seals in the valve blocks all good……try that don’t cost a lot and doesn’t take that long |
30th Jan 2024 6:41am |
ok, will do
30th Jan 2024 1:14pm |
no change i am afraid
6th Mar 2024 6:02am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
The cross-link valves in the later systems (MY07+) are a 3rd valve in each valve block, with the other 2 the corner valves.
6th Mar 2024 7:17am |
Are your lines coloured?
6th Mar 2024 12:37pm |
LRDirect show RQT000011 superseding to RQT000013, so OK to use 13 where 11 was originally fitted.
6th Mar 2024 8:22pm |
