Home > Technical (L322) > air suspension
Page 2 of 3 <123>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
well, i found it, nothing like it says in the book
it has only one valve for both front and rear, not two valves as per book
it is located under the drivers seat, forward of the air tank
261.80 euro RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #679938 10th Dec 2023 2:20am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
That don’t look like the valve blocks I have on my l322….. my front and rear ones look like this
Post #679943 10th Dec 2023 7:38am
will308f
The one in the middle is next to my compressor
Post #679944 10th Dec 2023 7:40am
will308f
Sorry just seen yours is an 2005 modal so they would be different Whistle
Post #679945 10th Dec 2023 7:49am
knares
hi, that’s the best pic i seem to be able to get
havent been feeling to good lately
and with the weather being up around the top 30 to 40 i have been hiding from the sun.
the pic is supposed to be 2002 to 2005
mine dose not have no 17
i removed the valve, shown in an earlier post but i could not see any thing wrong with it,
i reinstalled it, now i have no air to both front air bags and the warning lights are on (abs + which weren’t on before).
although the suspension was down on the left front, no faults showed up on the gap, now its showing a fault and a heap of others and i cant clear it.
i removed the two air supply pipes, which go to the front air bags but no air comes out.
now i am stuck RR 2005 4.4 petrol
Post #683662 23rd Jan 2024 2:16pm
knares
 RR 2005 4.4 petrol
Post #683664 23rd Jan 2024 2:33pm
will308f
can you hear your air compressor running ?
Post #683665 23rd Jan 2024 2:35pm
knares
any help would help, thanks RR 2005 4.4 petrol
Post #683666 23rd Jan 2024 2:36pm
knares
Yes, the compressor is working.
When this first happened there were no fault codes with Gap ID tool!
Now there is lots of faults.
I had it running for quiet some time, the compressor had switched its self-off, nothing was happening.
The height switch is locked, so I cant put it in off road or access.
I turned off the engine and a couple of seconds later the compressor came on and the rear lifted a bit to normal height.
Then I heard a short blast of air from the valve, the pipes to the front are still removed, then another blast, by the time I had got under neath to see where the air was coming from, there was another very short blast and no more.
A couple of days later I tried it again but there was no air blasts.
So there is no air to the front air bags. RR 2005 4.4 petrol
Post #684181 29th Jan 2024 5:15am
will308f
I was having similar issues,after renewing the rubber seals in the valve blocks all good……try that don’t cost a lot and doesn’t take that long
Post #684283 30th Jan 2024 6:41am
knares
ok, will do
Post #684316 30th Jan 2024 1:14pm
knares
no change i am afraid
changed the front height sensors
changed the valve as shown in previous post
changed the air susp ECU
i removed the air pipes to the front springs from the valve, no air comes out of them.
i went to the rover dealer, told them, my vehicle doesn't have a front cross link valve, as shown in the diagram, they said, no it doesn't, after me looking all over for it.
so, now i dont know which way to head RR 2005 4.4 petrol
Post #687308 6th Mar 2024 6:02am
GraemeS
The cross-link valves in the later systems (MY07+) are a 3rd valve in each valve block, with the other 2 the corner valves.
Can you follow the line from the centre valve block to check that you've refitted the lines correctly to the front valve block? Are your lines coloured?
Hmm, just caught-up a little. The valve block at the front was only fitted up to MY04.
Post #687312 6th Mar 2024 7:17am
knares
yes, yellow for the right side
black for the lift side
where did you get this information from, i only found this out to day and i have been looking for information for months, had to go to the dealers
can you tell me if the air susp ECU RQT 000011 and RQT 000013 are interchangeable.
ebay sellers say they are??
have you any information on the valve block, next to the tank
Post #687337 6th Mar 2024 12:37pm
GraemeS
LRDirect show RQT000011 superseding to RQT000013, so OK to use 13 where 11 was originally fitted.
According to Microcat 2012, RQT000011 was replaced by RQT000013 during MY04 production so your vehicle should have been fitted with RTQ000013. I've also found that Microcat shows the airline colours.
The valve block that you found for 261 Euro is aftermarket whereas the LR version around $1500. I couldn't spot a repair kit for the valve block.
I can't spot a wiring diagram for the valve block in the wiki but with the valve removed you should be able to operate each valve using 12V on probes trying the pin combinations. I would expect the ground wire for each connector to be either black or black plus a stripe, thereby identifying the ground pin.
The 3 electrical connectors shouldn't be able to be fitted to the wrong sockets due to different keying.
Post #687369 6th Mar 2024 8:22pm
Page 2 of 3 <123>
