Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts
Page 1 of 5 12345>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello,
I might need to replace the front pads in the next 2 months. Apart from punches (which I currently own none) are there special tools I need?
I am thinking of going with these:
EBC Greenstuff 6000 Elite Truck And SUV Front Pads DP62064
Do I need to replace the wear leads at the same time?
Are there other spare parts I should replace at the same time? Should I check the 2 pins and bolts before I start?
Many Thanks SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #676649 27th Oct 2023 7:11pm
caymanblack
I had mine out the other day pins and fixings were fine and the sensor lead was also all okay so I did not replace them just cleaned them and greased them. Just punch, socket set and some pliers, brake cleaner. overfinch modified
Post #676701 28th Oct 2023 9:19am
luxmoggy
This is the project next week. I am hoping the weather improves. Why is it always winter when I need to work on the RR? SDV8 AB MY 2020
Post #679143 30th Nov 2023 1:57pm
luxmoggy
Going well and then this pin is stuck…
Advice?
 SDV8 AB MY 2020
Post #679607 6th Dec 2023 11:20am
caymanblack
A good soaking with plus gas and then a light hammer on the punch to get it moving, keep spraying it .
If all else fails cut it. but with plenty of lube I think that will move. overfinch modified
Post #679608 6th Dec 2023 11:35am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I recently had to cut the bottom ones on both sides and then the last bit came out with a long punch. letters not necessarily in the right order
Post #679611 6th Dec 2023 12:58pm
caymanblack
Hey Lux how many miles has the car done ? Those discs look like they need changing also, must be all that Autobahn use. Wink overfinch modified
Post #679618 6th Dec 2023 2:40pm
luxmoggy
70,000 km.
One side done the bottom pin finally came out.
On the other side, the bottom pin doesn’t want to move. I might need to cut it. Disks feel ok. Might look at them in the spring.
Pin on left is the one that are fitted. The one of the right is the one from LR fitting kit.
How can I check the fitting kit part number? SDV8 AB MY 2020
Post #679620 6th Dec 2023 3:20pm
Gremlin500
Pin on the Right looks to be the correct one to me, the smaller diameter in the centre section locates the leaf spring. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #679621 6th Dec 2023 3:27pm
Phoenix
Post #679624 6th Dec 2023 3:44pm
luxmoggy
The thicker one are the one from the factory or were on the car from new.
While looking for my cutoff tool. I have felt the disc on the driver side inside. I need new discs. Also a new wear sensor.
It seems like the inside drivers side pad is stuck. The pistons might be sticking.
So tomorrow I call the garage about the parts.
I will make a plan over night. SDV8 AB MY 2020
Post #679629 6th Dec 2023 4:05pm
Dixy
You will need a large torx bit to undo the calliper and a big torque wrench to do it back up. There is a good YouTube video. letters not necessarily in the right order
Post #679638 6th Dec 2023 4:44pm
caymanblack
The calliper bolts that are tight are 21mm bolts. Once again they need a good spray and a nice long bar to remove them. overfinch modified
Post #679647 6th Dec 2023 5:53pm
luxmoggy
New discs, wear sensor & a rebuild kit ordered.
I will try with a clamp to remove the pin.
Would a blowtorch help or as the brakes I shouldn’t do it? SDV8 AB MY 2020
Post #679652 6th Dec 2023 7:12pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
High risk of melting the piston seals / dust covers before the caliper releases its grip on the pin.
Been there, done that Shocked Jonathan
2007 Defender 90 XS Hardtop
Post #679654 6th Dec 2023 7:25pm
Page 1 of 5 12345>
