Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1139 |
I had mine out the other day pins and fixings were fine and the sensor lead was also all okay so I did not replace them just cleaned them and greased them. Just punch, socket set and some pliers, brake cleaner. overfinch modified |
28th Oct 2023 9:19am |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 467 |
This is the project next week. I am hoping the weather improves. Why is it always winter when I need to work on the RR? SDV8 AB MY 2020
30th Nov 2023 1:57pm |
Going well and then this pin is stuck…
6th Dec 2023 11:20am |
A good soaking with plus gas and then a light hammer on the punch to get it moving, keep spraying it .
6th Dec 2023 11:35am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1094 |
I recently had to cut the bottom ones on both sides and then the last bit came out with a long punch. letters not necessarily in the right order |
6th Dec 2023 12:58pm |
Hey Lux how many miles has the car done ? Those discs look like they need changing also, must be all that Autobahn use. overfinch modified |
6th Dec 2023 2:40pm |
70,000 km.
6th Dec 2023 3:20pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1474 |
Pin on the Right looks to be the correct one to me, the smaller diameter in the centre section locates the leaf spring. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
6th Dec 2023 3:27pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
6th Dec 2023 3:44pm |
The thicker one are the one from the factory or were on the car from new.
6th Dec 2023 4:05pm |
You will need a large torx bit to undo the calliper and a big torque wrench to do it back up. There is a good YouTube video. letters not necessarily in the right order |
6th Dec 2023 4:44pm |
The calliper bolts that are tight are 21mm bolts. Once again they need a good spray and a nice long bar to remove them. overfinch modified |
6th Dec 2023 5:53pm |
New discs, wear sensor & a rebuild kit ordered.
6th Dec 2023 7:12pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 866 |
High risk of melting the piston seals / dust covers before the caliper releases its grip on the pin.
6th Dec 2023 7:25pm |
