Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
Hi,
6th Dec 2023 7:47pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1474 |
@Luxmoggy:
7th Dec 2023 9:30am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1216 |
Its 6Y mine are on the list for March 2018 SE SDV8 4.4 Byron Blue |
7th Dec 2023 10:30am |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 467 |
I knew about the wheel turning from watching videos before starting. I will add tap-out the pins to the summer/winter tyre change - add copper grease as needed.
7th Dec 2023 10:36am |
This is like lots of little jobs they are small. Just change the brake pads. - a few hours - due to stuck pins.
7th Dec 2023 10:47am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8232 |
Do not use copper slip on alloy callipers, makes the alloy the sacrificial anode and rots your callipers quicker than spraying them with salt water....!!!! They sell alloy calliper brake grease.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
7th Dec 2023 10:56am |
So with the pin cut it is now out.
7th Dec 2023 1:49pm |
I did all 4 last year during my “big brakes” upgrade, it was a b*tch to bleed the brakes fully, you need to run the ABS pump with iiD tool or similar to purge the last bit of air. (To be fair, I might have done better if my collection vessel allowed air out! ) @Luxmoggy: Plus Gas is what you need, soak the bolts the day before. Renew the bleed nipples, and very carefully wrap only the threads in PTFE tape to stop them rotting, it creates a physical barrier between steel & aluminium. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
7th Dec 2023 2:12pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1139 |
T50.
7th Dec 2023 4:33pm |
PlusGas is not readily available in Germany. So have ordered some Liqui Moly Pro-Line Schnellrostlöser. I hope that works.
7th Dec 2023 6:11pm |
How big of a bar? and how much strength/weight to get them to move the 2 bolts? Today new axle stands arrived. They are bigger than my current ones which are are max extension to get the height needed. I will be happier trying with the bar on them. SDV8 AB MY 2020 MINI Cooper S Cabrio Kit: Jaguar XK140 (in progress - the website is link to build) |
7th Dec 2023 7:28pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1094 |
They torque up at 230 Newton meters so they are FT even when freshly done up. letters not necessarily in the right order |
7th Dec 2023 7:57pm |
Just seen that my air wench max torque is about this so it will never undo them.
7th Dec 2023 8:35pm |
I bought this one , this with the plus gas soaked over a few days done the job.
7th Dec 2023 9:36pm |
