Home > Maintenance & Mods (L322) > Battery charging via towing port question
Page 2 of 3 <123>
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Seems like Anderson plugs have not been taken up in The UK like in OZ. Anything to do with battery power and charging, I would be running a decent thickness cable to the rear Fusebox with a re-setting fuse. Fit the Anderson plug somewhere convenient outside the car..
https://www.amae.net.au/2019/07/11/what-yo...iler-plug/
https://www.aliexpress.com/item/1005006046...Redirect=y 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #678483 22nd Nov 2023 8:10am
FullfatSteve
Whilst I wait for the 12s very convenient connector, I fitted the ctek with the not so convenient cable to the battery… what pain in the rear. Lost socket down in the engine, spent next 30mins fishing for it..but luckily got it. And now the ctek is doing something… I think???
Here’s a photo of the ctek. It’s my first time using one , guess just sit and wait and hope the lights go up? Rolling with laughter
Post #678487 22nd Nov 2023 10:15am
Gremlin500
Yes, correct, the lights will progress up to 5, when the green battery symbol will illuminate.
You can just leave it connected.
Do you have an AGM battery? Looks like you haven’t selected AGM mode.
DON’T ever use “recon” on an AGM Battery, the voltage gets too high! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678490 22nd Nov 2023 10:44am
FullfatSteve
Thanks Germlin500 for the info, appreciate it, as you can tell, I am not in anyway a mechanic lol.
I should really have the username dangerous dave Rolling with laughter
I am sorry to say this, how do I tell if I have an AGM battery? I saw it was a JLR battery on her.
I can post a photo if that would help?
Post #678492 22nd Nov 2023 11:06am
FullfatSteve
Back again..
So I see the letters AGM on my battery and assumed it was ok to press mode on ctek and now AGM light is on. No idea what it does but hoping it’s doing something better than without AGM light on Laughing
Post #678496 22nd Nov 2023 12:39pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Much better job than faffing around with trailer wiring.
They are used extensivly on HGV's - easy to jump start from one vehicle to another and non-reversable.
AFAIK the AA/RAC use them for jump starting off their vehicle batteries.
Post #678498 22nd Nov 2023 1:20pm
FullfatSteve
Another update, light is up to number 4.... I wonder how long it will take to go past 4... or, if I should expect it to go past number 4, anyone have any insights?
reading post previous... I assume it will get up to 5, just need to be patient...
Thanks again all.
Post #678513 22nd Nov 2023 4:49pm
FullfatSteve
Well, this is going from bad to worse Big Cry
After battery charged, thought I’d take her out for a drive, fires up a lot better. 10minutes in and stopped . Got out for about 15minutes, got back in , fires back up and then displays restricted performance, never had that before. Selected ok and drives fine, easy up to 70 and zero restricted performance… was my battery top , now a knock on effect , any ideas?
Post #678530 22nd Nov 2023 8:38pm
FullfatSteve
Update..
After stopping for chip shop, got back in and no warning light and drove home, again fine.
I really have no idea now what is going on. Guess will see if it comes back on next time I use it lol
Post #678534 22nd Nov 2023 9:44pm
DrRob
You need a GAP IID Bluetooth when running an L322. It's THE most invaluable/cost saving device you can have. Its reads codes, clears codes, CCF updates, live values etc etc. Not cheap but hold their resale value extremely well! Often come up on here / sister forums for sale secondhand.
Update your signature to record what engine you have. I think you have the 3.6
An RP could be a number of things from a split hose to cracked manifold. A high pressure smoke test required.
You're in Bristol I see - Craig from Cam Tech or Steve Norman (T&S Norman) in Shepton Mallet are you go-to! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #678547 23rd Nov 2023 8:32am
FullfatSteve
I have hopefully updated my signature now...lets see what happens when I press send on this Laughing
Yes it is a 3.6. I have been looking a lot at the gap tool and thinking, that would be epic toy to have, but trying to justify that is hard, as I can spend the dosh on full set of wheel nuts and other things needed lol.
I will see if the triangle of doom comes back, I will take it out for a longer run.
Hopefully, my 12S connector arrives today and then I bet the socket or something else won't work or charge the battery Rolling with laughter 2009 Facelift Range Rover Vogue SE 3.6 TDV8
Previous cars :
2018 Range Rover Velar D300 V6
Post #678564 23rd Nov 2023 12:26pm
Gremlin500
Just thought I’d post this up from the CTEK Manual in case you don’t have it, shows what is happening and how long it takes for the various stages:
Post #678566 23rd Nov 2023 12:56pm
FullfatSteve
Thanks Gremlin, I do have the manual as I bought it new. Yesterday, I got to the battery light number 7 before I disconnected it via the battery connectors.
12S connector arrived, plugged it in and used multi meter and nadda, nothing , nowt, dead. I have checked the 2 fuses that looks like they are to do with trailers and fuses look good, I even replaced them but still no power out of it. Guess next stage, will be to attempt to see if anybody previous to my ownership stolen the power for something else.
If anyone else got any ideas, shoot them my way, thanks all. 2009 Facelift Range Rover Vogue SE 3.6 TDV8
Previous cars :
Post #678594 23rd Nov 2023 4:48pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Looking at the current state of your towing plugs I would give the pins a good clean then check each one out to see if they are actually connected. I’ve had the wires in the rear of my plugs corrode and snap and it can happen rather quickly too. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #678606 23rd Nov 2023 8:04pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Based on the state of those connectors, the wiring's probably just corroded away.
One of the first things I did on my 2012 was change the two 7N/7S connections for a 13-pin. So much better towing electrical system than the old-style two-plug setup. When I took the two 7-pin connections off, half the wiring was broken and they didn't look as bad as yours from that pic. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #678619 24th Nov 2023 10:42am
Page 2 of 3 <123>
