![]() | Home > Maintenance & Mods (L322) > Battery charging via towing port question |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Same here. I binned the old plugs and fitted a brand new genuine 13pin one for the sole purpose of charging via an adaptor and ctek.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Dead easy. I bought a 13pin 'dual entry' socket which is intended to allow conversion from 12N/S to 13pin and allows both the cables to be entered into the socket via a grommet with two cable entries. Just a case of matching the original cable assignments to the new socket. Easiest done by removing the entire sub-loom from where it plugs into the vehicle loom so it can be worked on at the bench. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 46 ![]() ![]() ![]() |
Did this mod today, just a standard 13-pin plug and a charger, couldn´t be any easier.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
I need to do the same thing, but I have the older 7 pin plug aka 12N
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 57 ![]() ![]() |
A curious question, would it be possible to do any modd so you can charge the battery at EV charger stations via the towing port? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
No idea, but if I were a betting man, I’d say no, as the battery technology is completely different and so charging rate, voltages etc will be massively different.
No, the EV stations use 400 volts ( not 12V ) , some of the newest ones for Porsche Taycan's etc use 800 volts ! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1680 ![]() ![]() ![]() |
400V/800V into a 12V battery, wow that would be super fast charging!⚡️ |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
[quote="pcourtney"]I need to do the same thing, but I have the older 7 pin plug aka 12N
