![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 294 ![]() ![]() ![]() |
I have added soot, it’s around 17g, not sure if that’s a lot or not? Lots of passive reagens seen, as you say, but they do absolutely nothing as far as I can see! FFRR SDV8 Autobiography |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1276 ![]() ![]() |
James its OK at 17g, I think mine starts its AR just over the 20.5 gram mark and stops below 6 gram.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1607 ![]() ![]() ![]() |
@KOT:
It’s all to do with the profile you are using, search all the pid’s (parameters) in your profile.
I think it's time to upgrade you from 'nerd' to 'professor' ![]() I shall remain patient until I go over 20g and report back! FFRR SDV8 Autobiography |
@KOT:
Long trip to Wales this weekend, had been sitting at 100% trigger for weeks. As soon as the soot level passed 20ish grammes along the A55 it went straight to active regen. After a good 20 mins regen it had dropped to below 7g. Superb. |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 471 ![]() ![]() ![]() |
100% for weeks. I know what this is. And this is the reason I have the km since last regen and average km between regen.
So today I debunked the theory that you need 1/4 tank of fuel or more for an AR.
I have to admit I’ve wondered why the 1/4 tank rule would be a thing when in reality the regen only lasts for say 20 miles or so?
Yes down to 5.5g at the end of AR, shows how just relying on the % pid puts you in the dark. 2018 SE SDV8 4.4 Byron Blue |
I am looking in "Car Scanner" I can only see "Calculated soot in oil" in grams. Is this the correct sensor for the soot grams? SDV8 AB MY 2020
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 106 ![]() ![]() ![]() |
[ECM] DPF soot 2017 (67) Vogue SE Corinthian Grey |
