Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol
Page 15 of 27 <123 ... 141516 ... 252627>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I use demo and look at all sensors
I have the following 3 listed
DPF/GPF Soot (Normalized Trigger for PF Regen) %
ECM Calculated soot in oil g
ECM DPF soot concentration g/m3
Profiles DB: 1.101.8 SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #678379 20th Nov 2023 7:05pm
Kot
No
I use "[ECM] DPF Soot" in profile Range Rover, Range Rover 2017-2021 I got this created by developer mainly to catch the SDV8 facelift series as previous profiles didn't have the g soot etc
NB- there are profiles under LandRover and Range Rover tabs.
If you dont have a pid you want that in your profile, email developer he may be able to add it. 2018 SE SDV8 4.4 Byron Blue
Post #678381 20th Nov 2023 7:06pm
luxmoggy
OK, I have now seen it. I will ask for the "ECM DPF distance since last Regeneration" to be added to the "Range Rover, Range Rover 2017-2021". I can then start using this profile - which is more correct for my car.
Current Use "Land Rover, Range Rover 2013-2016 V8 4.4 Diesel", which is the only one I think I have seen with the "distance since last regeneration" sensor. SDV8 AB MY 2020
Post #678382 20th Nov 2023 7:18pm
CerebralThunder
I hope somebody can help,
I have a 2015 SDV6 3.0 Hybrid RR AB but could not see a profile for this car. What do others do with this same engine?
Maybe I'm looking in the wrong place?
Thank you.
Post #678406 21st Nov 2023 2:21am
Gremlin500
You don’t actually HAVE to use any profile, -you can just choose “all sensors”, (assuming you know which sensors you wish to select). Once you add these to “Demo Mode” and customise the screen, your sensor selection & layout is saved for next time. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678429 21st Nov 2023 1:31pm
Gremlin500
Hmmm, I just changed mine to include “Miles since last regen” (as well as “Average distance between PF regens”)
It looks OK in Demo mode, but when I connect it to the car, I get 92738 (or similar) Rolling with laughter as a value (since last regen) and no units displayed (or selectable) Sad
Obvs I’ve gone wrong somewhere…… Embarassed
Suppose I could use that screen position to display Soot grams instead, but %Soot is already at the top of my screen, which I find more useful than grams. I’ve set % soot to go from white text to red at 50% (which is when an AR is due) then from white to green under 10% soot. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678431 21st Nov 2023 1:51pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Your “miles since last regen” is in metres (so you’ve done 92km or around 55 miles), I can’t get it to display miles or km, just m 2017 (67) Vogue SE Corinthian Grey
Post #678442 21st Nov 2023 5:25pm
luxmoggy
Mine is in KM for that sensor. SDV8 AB MY 2020
Post #678453 21st Nov 2023 7:12pm
Gremlin500
@Luxmoggy:
So, is it the vehicle, the dongle firmware, or the phone software to blame?
Any idea how to update/reflash the Vgate dongle? Is it even possible? Bow down “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678489 22nd Nov 2023 9:35am
luxmoggy
I think it is in the software
As you can see the value is in KM
What profile are you using? What unit does the sensor say it is? SDV8 AB MY 2020
Post #678506 22nd Nov 2023 2:17pm
Kot
Open the PID select tab-sensor properties and you can select miles see screenshot
Post #678525 22nd Nov 2023 6:54pm
Abacus405
That’s the average distance between regens, not distance since last regen 2017 (67) Vogue SE Corinthian Grey
Post #678527 22nd Nov 2023 6:58pm
Kot
Just seen the ECM pid doesn't allow units etc but there is an Average Distance between dpf Regens in the list which works.
Guess you need to email developer if you really want it adding. 2018 SE SDV8 4.4 Byron Blue
Post #678528 22nd Nov 2023 7:02pm
Gremlin500
Hi Kot, I’m using “all sensors” as its just not there under the profile for a 2017 V6, this is what I see:
i.e. no units under “Sensor Properties” Sad “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678529 22nd Nov 2023 7:02pm
Gremlin500
Never mind all that, I just got excited Embarassed by the possible use of the App as a HUD, by mirroring the phone screen, choosing black background, turning phone brightness up to 100% and placing on a tacky pad on the dashtop. Thud Shocked Very Happy
Anyone tried this yet? Any good? Sheep “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678536 22nd Nov 2023 9:37pm
