![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 106 ![]() ![]() ![]() |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 471 ![]() ![]() ![]() |
Theses are the sensors I use
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 ![]() ![]() ![]() |
For my 2020 SDV8 4.4 I use the following profile. As at the time the profile for the 2020 wasn't there. I still use it as one of my sensors isn't in the newer profile.
Found it.. in a different sensors list under the settings option. I am not sure how i get it to appear under the 'All sensors' icon though
This is the same as mine. So I can see the correct sensor in the Sensors list within Settings, i just need to work out how to get it to appear in the All sensors list 2016 AB SDV8 Barolo black |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1593 ![]() ![]() ![]() |
#2 I can recommend Luxmoggys choices, I plagiarised the same ones! |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 294 ![]() ![]() ![]() |
Does anyone know if the service indicator being at the stage of "Service due now" (i.e. zero miles left) will prevent an active regen from happening? FFRR SDV8 Autobiography |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1265 ![]() ![]() |
I would definitely think not, what would be the use of that?
My thinking was "the service due NOW indicator has been cause by multiple failed regens, therefore the vehicle will stop attempting them as it will only serve to make the diluted oil worse, and hope the owner does actually get the vehicle serviced immediately"
=<3000 miles is what I usually get with minimum interrupted AR's.
Exactly.
Just done another two long motorway runs with regen at 100% as it's been for weeks now. Still no active regen. So I'm pretty sure the vehicle is not doing it as the service now indicator is on. Hopefully will clear after next Thursday once it's been into the garage! FFRR SDV8 Autobiography |
I now use a PID which also has the soot in grams, it's really a better way of knowing exactly what the calculated value is, rather than the 100% value, which after a incomplete AR, still shows 100% regardless of what the true amount of soot left in the DPF actually is.
