![]() | Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Thanks Nylands.
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 199 ![]() ![]() ![]() |
Thanks GraemeS
Nothing has changed with regards to dealer updates.
No response from JAE yet so probably not going to get one. I'm now looking at the possibility of producing a small adapter pcb to fit inside a USB-A male on a FW/USB adapter at one end and inside the nav connector at the other end to overcome the pin spacing difference and to cross rx/tx too if shown to be needed when my FW lead and USB adapter arrive. |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
This all sounds exciting and positive.
I'm at the point of needing an AU/NZ DVD update disc suitable for a 2005-2009 L322 that is later than the 2010 version on my system.
Ignore that - just checked your location. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 881 ![]() ![]() ![]() |
I am trying to modify MY11 ( Denso HDD ) to MY12 USB GEN 2.1 HDD, so that I can use the latest 2020/2021 maps/update
Modify in what way? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Modify is the wrong word, "would like to modify" is more accurate |
Johnfin Member Since: 18 May 2021 Location: Lyon Posts: 8 ![]() ![]() |
Hi Guys,
Reading through the "Information and Entertainment Systems..." it clearly states that it is Firewire connection between disk and the IAM2.0:
One more update...
