Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering
Page 10 of 10 <12345678910
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
2010-2012 sat nav map updates
Hi everyone
Great to see the latest postings here and although I don't follow the technical references to leads and equipment mentioned, it seems as though you are close to finding a solution for updating maps on the 2012 L322 RR etc.. That would be a very welcome outcome and I wish you success in this.
Good Luck Bow down
Post #675233 10th Oct 2023 9:54am
GraemeS
Thanks Nylands.
Updating earlier and later systems is very straight-forward and I now believe updating our HDD systems is also very straight-forward but requires the temporary use of an external HDD. I'd like to use the correct connector so that anyone can update but my Plan B would be to replace the special socket with a USB socket. FW 6-pin female to USB-A male adapters are readily available but Firewire requires pair A and B to be crossed between the 2 devices which would have been done in the LR lead as is done for all FW device connecting leads (but not extension leads) so a USB-A socket must be appropriately wired.
Post #675238 10th Oct 2023 10:31am
Nylands
Thanks GraemeS
So are we saying that the main dealer is now in the position to carry out a current map update for the later L322 models now if we wanted it? I contacted my nearest main dealer two or three years ago for an update but without any interest on their part. Have they caught up then or do you think it's going to have to be a DIY job should you want it?
Thanks
Post #675240 10th Oct 2023 12:03pm
GraemeS
Nothing has changed with regards to dealer updates.
I have no knowledge of what maps are available for the UK but AU "LR" map discs right up to current versions are available but are marketed as only suitable for vehicles that use a DVD map disc, not HDD or USB stick systems. I expect the format of these discs to be useable as it has already been found that the map files themselves didn't change for the HDD systems. However whether or not the security code on a new disc is the same one that the map update function requests is yet to be determined but my costs to get to that point are minimal so worth the attempt.
Making available latest maps on DVDs that can only be used directly on old DVD-based systems suggests to me that there is an expectation that they could be loaded onto a HDD or USB to update those systems. The Australia V26 2020 DVD costs $100 which seems a reasonable compromise between cost and age compared with Australia V27 2021 costing $200 then bigger steps to the later versions, yet retaining use of the inbuilt nav system rather than using another display. If successful then updating to later maps in a few more years for another incremental cost would be an option.
As JAE lists over 650 MX39 part numbers marked to be obsoleted and that the harness connectors are only available fitted to a harness, I'm wondering if JAE made the harnesses themselves and therefore would have made the harness that we require. My inquiry included enough detail for the particular harness to be identified, not that I consdered at the time that JAE might have made them.
Post #675258 10th Oct 2023 8:16pm
GraemeS
No response from JAE yet so probably not going to get one. I'm now looking at the possibility of producing a small adapter pcb to fit inside a USB-A male on a FW/USB adapter at one end and inside the nav connector at the other end to overcome the pin spacing difference and to cross rx/tx too if shown to be needed when my FW lead and USB adapter arrive.
Post #675478 13th Oct 2023 11:13am
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
This all sounds exciting and positive.
Is there anything the rest of use can do to help you with this? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #677718 11th Nov 2023 12:29pm
GraemeS
I'm at the point of needing an AU/NZ DVD update disc suitable for a 2005-2009 L322 that is later than the 2010 version on my system.
I have a USB+FW external HDD and a copy of the Denso map update program which is stand-alone even though normally invoked from SDD which has prepared the external HDD. I have FW to USB-A connector cabling which has the 4 data wires to the USB-A connector for which I have designed a small link pcb to mate with the satnav's connector which I will have made if I can get the Denso program to load a test map to the HDD.
I recently placed an order for an inexpensive AU/NZ 2016 map set for a 2005-2009 L322 from a site that I've been warned to be cautious trusting, but with no reply from an inquiry sent immediately after placing the order, I doubt that I'll be persuing that source. The order required my vehicle's VIN for which I supplied only the last 6 digits which are outside the serial numbers for 2005-2009 vehicles which may have been an issue or more characters might be required to generate the code, but with no reponse and only bank transfer payment I too am suspicious of the site.
Post #677731 11th Nov 2023 8:19pm
MartinD
Ignore that - just checked your location. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #677733 11th Nov 2023 8:33pm
pcourtney
I am trying to modify MY11 ( Denso HDD ) to MY12 USB GEN 2.1 HDD, so that I can use the latest 2020/2021 maps/update
https://www.satnavupdatestore.co.uk/land-r...-821-p.asp
LAND ROVER "DENSO" KNOWN AS "InControl Touch" USB GEN2.1 HDD 2020/21 EUROPE UPDATE
SUITABLE FOR LAND ROVER / RANGE ROVER VEHICLES WITH USB GEN 2.1 HDD NAVIGATION SYSTEMS.
COMPATIBLE VEHICLES
New Range Rover (MY2012 - MY2015)
Freelander 2 (MY2013 - MY2015)
Range Rover Sport (MY2012 - MY2015)
Discovery (MY2012 on )
Discovery Sport ( MY2015 on )
Evoque (MY2012 - MY2015)
Post #677737 11th Nov 2023 9:28pm
MartinD
Modify in what way? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #677741 11th Nov 2023 9:58pm
pcourtney
Modify is the wrong word, "would like to modify" is more accurate Smile
The JAE MX USB2 Series of connectors are key, see below, however the Socket Connector and the Relay Connector were only available as a "Harness Product and not sold as an individual connector"
So either the "Straight Pin" or "Angle Pin" might be available as old stock as individual items, Part Number MX39004UQ1 also MX39004NQ1 - but still not all that helpful to us as we need the "Socket Connector" to easily connect into the Head Unit - as shown in the second screen shot below, right hand side of the photo showing the mating of the male & female connectors
https://www.mouser.co.uk/ProductDetail/JAE...xq4Q%3D%3D
Post #677748 11th Nov 2023 11:55pm
Johnfin
France
Hi Guys,
With the New 2025 Year, I came back to this subject and am wondering if you've been able to make any progress? Nothing at my end, unfortunately.
With that said, I've seen Disco 4, late pre-lift builds with IAM2.1 units though rest of pre-lift units/lights and most importantly ZF6 gearbox whilst the newer models were ZF8. The reason I mention it, is apparently the ZF6 worked on slow speed can whilst IAM2.1 required high-speed can.
Maybe an easier way would be to upgrade the IAM2.0 (Denso units) with IAM2.1 units and just use newer maps?
@GraemeS, have you been able to make progress with your external HDD?
All the best to all of you in this New 2025 Year!
Post #708020 1st Jan 2025 5:36pm
Johnfin
France
Reading through the "Information and Entertainment Systems..." it clearly states that it is Firewire connection between disk and the IAM2.0:
Connect the navigation update tool to the vehicle using the firewire cable.
They refer to the external HDD as "navigation update tool".
Since there's a struggle with the socket - how about replacing the socket with the earlier mentioned USB socket? Hopefully that wouldn't cause much interference and would solve the problem.
Reading through that document at other level, it mentions that the piece of software to prep the disk, takes maps from DVD master set (2 disks).
Post #708024 1st Jan 2025 6:24pm
Johnfin
France
One more update...
Apparently the external HDD unit might look like this .
This apparently shows 6 pin Firewire 400 ports.
There are ready available cables 6 to 4 pin Firewire 400. (aliexpress.com/item/1005003247825844.html)
Does this solve the problem? Where do you have guys the connector on your FFRR?
This cable could be ordered for cheap and you might be able to verify easily if it just fits and the mistery with the socket would be sorted then.
Post #708028 1st Jan 2025 6:36pm
