![]() | Home > Maintenance & Mods (L405) > Alternative to L405 gear selector |
The part number for the console / bracket is LR045000
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 160 ![]() ![]() ![]() |
They took my offer for $30++ on the sub frame.
I texted a couple of buddies that work in Roswell NM. They reached out to some of their 'contacts'... Turns out that "Donna" will actually be the only L405, and I quote, "in the known Universe" with a pistol grip shifter.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1466 ![]() ![]() ![]() |
I am blown away by your commitment |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
those little grey men in roswell are pretty clever so i'm sure they'll help to find a solution... |
I am still seeing this as a Proof of Concept exercise - UNTIL - we can close up the console. Having a pistol grip is cool and all - but a gaping wound in the middle of the truck kind of kills the understated opulence vibe of the Flagship... Throwing out some cost numbers for a "Bring your own Pistol" kit... Subframe - new $150 (I only saw 1 LHD 'Merica! on eBay and snatched it up) L405 to L494 Conversion Pigtail - $50 3D Printed Extended L494 Bezel - $50? (not my area of expertise..) Nutserts to mount the subframe and various other hardware - $50 $300 - you could get a kit. Find a Pistol Grip for around $400 and convert your truck to a Pistol Grip under a grand... I wonder if my Grey buddies know anyone that does 3D printing? PS - @Phoenix - it looks like the Scab and the L405 Pigtail may be in today's mail run... I will get you some pics as soon as they come in. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 Last edited by JDGeorgia on 27th Oct 2023 9:10pm. Edited 1 time in total |
I was looking back at all the info supplied and saw this from Bora20 a few pages back...
The LaShonda the Mail Lady rang twice today!
Cheers for that - I was thinking of positioning - there is a spacer to the rear of the L405 shifter - if the L494 shifter was moved into that space, it'd give more hand clearance between the shifter and the more upright instrument panel. The spacer could be used as a closing panel in front of the L494 shifter - possibly.... |
Are you talking about this as the 'Spacer'?
Yep, that's the spacer - as you say, non-destructive modification only!
Andy... Andy... Andy... I read this about 2 or 3 weeks ago now and thought - "Yeah, how hard could this be?" Andy is off the Christmas Card list. In other news - I used the bezel to calculate the rearward tilt of the Pistol Grip. It comes out to about 21.5* and with the grip being about 150mm tall that moves it back from the climate buttons 60ish mm or not quite 2 1/2".
Given that it was not right up on the buttons before, even with my fat sausage hands - that should be plenty of clearance... Right Clarence? There isn't an easily findable mating connector for the (TE again) L405 shifter connector so I've sent a spread of emails to various suppliers - it'll be next week before I have answers. @Phoenix - so you can't find the mating connector (which I don't need because of the Scab) - can you take an educated guess on pins that will fit the Scab? worse comes to worse... I can sand them thinner on the belt sander. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
The pins are the MQS 0.63 x 0.63mm, there's a TE part number in the first TE link, I'll dig it out later after work. |
As I say... if nothing else, I am coachable...
